OPL2LPT
Reply 520 of 533, by keropi
all these formats/devices...wow modmaster will be the only player one ever needs, kudos!
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 521 of 533, by mateusz.viste
I'd be keen on adding OPL3LPT support to DOSMid, so it could be used on 286 laptops and such. Where can I find the specs for the expected LPT output? I would also need some testers once implemented, since I do not have the device myself.
http://mateusz.viste.fr | gopher://gopher.viste.fr
Reply 522 of 533, by digger
mateusz.viste wrote on 2020-07-13, 13:59:
These are the programming examples you're probably looking for:
I agree that these code samples are a bit hard to find, being hidden inside a closed GitHub issue thread. Perhaps they should be listed in the project's README file as well.
Reply 523 of 533, by dreamblaster
i will add to first page in this thread
OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
S2+X2 special bundle : https://www.serdashop.com/DreamBlasterBundle
Thanks for your support !
Reply 524 of 533, by digger
dreamblaster wrote on 2020-07-13, 18:52:
Something went wrong when you copy/pasted those links to the opening post. They don't work there now. The trick is to not just copy/paste the text of the link, since the forum abbreviates the text of long links. Instead, right-click on the links and then select "copy link location" (or whatever your web browser calls it). Then you'll get the actual full URL in your clipboard.
Don't worry, it's a common mistake, which I've also made a few times myself. 😅
Reply 525 of 533, by dreamblaster
digger wrote on 2020-07-15, 09:59:
Tnx, solved 😀
Reply 527 of 533, by dreamblaster
phantomtypist wrote on 2020-10-28, 03:24:
Are there any gerber files for the OPL2LPT? I really don't feel like paying 21% VAT for something going to the USA.
No gerber available.
If you dont wish to buy from Europe (shipping times are also large these days) , you could consider OPL3LPT instead :
this is available from 8 bit guy : http://www.the8bitguy.com/product/opl3lpt-ad- … lel-sound-card/ (but he is out of stock at the moment)
or from excel valley : https://www.excelvalley.com/product/opl3plt-synth/
Reply 528 of 533, by tyukok
I tried using ADLiPT TSR on my Windows 98 machine in DOS box, but it tells me that a wrong version of EMM386 is installed. But the version that comes with Windows 98 is 4.95, well above the required 4.46.
What am I doing wrong?
Reply 529 of 533, by matze79
You running it under windows but it only works in plain dos
Start your computer in DOS Mode
Co2 - for a endless Summer
Reply 532 of 533, by dreamblaster
kleung21 wrote on 2021-04-28, 06:17:
Hey Dreamblaster.
Any update on stock?
Thx in advance
well i do have opl3lpt in stock
opl2lpt not at the moment
i may do another run if it makes sense
but opl3lpt is a nice replacement i think
Reply 533 of 533, by sofakng
Is there any reason to buy opl2lpt instead of opl3lpt? (ie. any reason to use an OPL2 chip instead of OPL3? is OPL3 fully backwards compatible/same sound as oPL2?)
By the way, I just ordered from ExcelValley (opl3lpt) but I was told they ship from China. It looks like there is no quick way to get these in the USA 🙁
