First post, by deksar
Hi retroers.
I've an IBM PC 300GL computer which has its own internal PC speakers, (not beeps and buups, that's real speakers in the PC case), but it has a horribly high speaker volume level and it's quite loud and disturbing. How to decrease the volume level on those computers?
Either with jumpers, or with a tool on MS-DOS? Couldn't find any such jumber on the mainboard.
Any idea? Thanks.
Reply 2 of 7, by badmojo
I'd be surprised if there was a way to alter the volume of the PC speaker but you never know with an OEM.
On my clone 286 I ended up slicing a resister into the PC speaker wire and that worked well - a bit fiddly because you need to find the right resistance, but if you have a few to try then you can simply switch them in / out until you find the right level.
Reply 3 of 7, by yawetaG
When the internal speakers are also used for actual music, they usually are connected to the integrated sound card on the motherboard, and you can control the music and sound effect volume via the mixer controls (beeps etc. are unaffected).
Reply 4 of 7, by deksar
Using ES1930/ES1989 drivers, there is no mixer that's included with the driver. I tried manually downloading DOS versions of ESSVol, ESSMixer executables, however these tools couldn't detect the audio card.
It's really disturbing..
Reply 5 of 7, by badmojo
Apologies! I didn't read the OP properly.
