Reply 920 of 927, by FreddyV
audiocrush wrote on 2022-10-02, 00:56:Hi, is there any special trick to run this software properly? I can't seem to get anything but crackles and pops out of this sof […]
I can't seem to get anything but crackles and pops out of this software.
Does it require special hardware requirements like specific display modes or a minimum amount of memory?
My system has got a 8088/8087 that I can run from 4,77MHz to 10MHz, 512k of ram and a Soundblaster 2
On this machine, you can expect 14KHz at 4MHz or 26-30KHz at 10MHz for a 4 channel module.
The pop can be due tothe fact that the volume is too high, then there is overflow.
Your SB2.0 probably have a problem ?
