First post, by McBierle
"Quick" question:
I recently got a CM-64 without cables. I made a cable via this http://amorphe-welt.de/bastelei/midi/midikabel.html
DIN - D-sub
2 - 4
4 - 8
5 - 15
After a quick test i diddn't get sound, so i want to know if this pinout is correct, so i can rule the cable out.
Thanks
Reply 1 of 12, by keropi
this is a simple schematic for a gameport->midi-out adapter:
you connect it to the CM-64's IN port and it will work fine... straight cable connections are not a good idea.
Reply 2 of 12, by McBierle
Ok thanks, if i get a 74LS00 i'll do that thing.
But, should i have gotten sound or not? What will/would happen with a straight connection?
What about those midi/gameport-cables you can get on amazon/ebay? Do the have this circuit?
Reply 3 of 12, by gdjacobs
Quite a few ways it can go wrong when directly connected. Part of the reason for the physical connection spec is that it's much more predictable.
Reply 4 of 12, by Tiido
With direct connection there may not be enough current to drive the LED in the optoisolator on the receiving end, depending on what sort of resistor is used in series with the MIDI line.
Reply 5 of 12, by McBierle
keropi wrote:
this is a simple schematic for a gameport->midi-out adapter: […]
Ok got a 74LS00. Ist pin 15 not connected? or ist there a line missing in that graphic`? And 8 and 9 are not connected?
Reply 7 of 12, by keropi
yes the schematic is edited to only include the MIDI out port , the IN port requires some more components and it is not needed for gaming/playback
Reply 8 of 12, by gdjacobs
By convention NAND gate pins 1, 2, 4, and 5 should be strapped to ground (or +5V) and not allowed to float.
Reply 11 of 12, by McBierle
Yes exactly, but in that pic/schematic the din-connector is "midi out".
edit: i know, i'm counting beans here. I know that the midi signals are going out on that side. But if you have a connector on a device that is called "midi out" i would use another description 😁
Reply 12 of 12, by McBierle
Oh i forgot, many thanks it works!
245.04 KiB
