Reply 860 of 924, by darry
TehGuy wrote on 2022-04-15, 21:50:
darry wrote on 2020-10-29, 01:58:
This Orpheus specific driver looks like it is based on the reference pv2860.zip driver set, so I tried to install that instead and it works fine for me, AFAICT (the only change I made is a registry key to enable digital output).
Digging up a 2 year post, but what did you end up changing if you remember? I'm trying to activate the SPDIF out so I can run my rig through my DAC and onto whatever else i need
You should be able to get the key name from the INF file or modify the inf and reinstall the driver.
Re: Orpheus Soundcard: a new DOS soundcard with SPDIF/OPL3/MPU support
@keropi @marmes Maybe that info should be added to http://www.pcmidi.eu/orpheus.html . Sorry if it's already there and I missed it .
Reply 861 of 924, by TehGuy
darry wrote on 2022-04-15, 22:23:
You should be able to get the key name from the INF file or modify the inf and reinstall the driver. […]
Ah hopefully that'll stabilize things on that end; now I'm just stuck with the MPU-401 not being found or activating or something under DOS. I've half a mind to get a really long MIDI cable to run to my interface and just nuke the mt32-pi setup I have all together, but part of me thinks the pi isn't the problem right now. Man, only thing I swapped in this rig recently was the 2MX 400 for a 4MX 460 and everything goes bonkers
Win98+DOS: VIA C3 Ezra-T 1.0AGHz / P3 866MHz, 128MB RAM, AWE64 + Orpheus, GeForce 4 MX 460, 128GB SD card
Win XP SP3: C2D E8500, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
Reply 862 of 924, by red_avatar
My card arrived yesterday (thanks for the sweets). I'll be testing it this weekend and will probably have a great many questions. I'm focusing on the Dreamblaster X2GS for now which was included.
I actually already have one question: if I add the X2GS to the card, can I chose whether to use the X2GS or to output to my SC55 through the Midi port without having to change jumpers?
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 863 of 924, by keropi
red_avatar wrote on 2022-04-21, 08:15:
nope it is not possible to do this choice without using the jumpers , the easiest way IMHO to achieve this is to enable CSMPU@300 and jumper WT header to CSMPU
then PCMIDI will reside at the standard 330 that older games love and you can have your external modules connected to jack and/or gameport midi
so depending on situation you select in games if you want to use ports 300 or 330 and the corresponding device will do the playback
🎵 🎧 PCMIDI MPU , Orpheus , Action Rewind , Megacard and MK8330 soundcard website
Reply 865 of 924, by keropi
stef80 wrote on 2022-04-21, 08:27:
What is average waiting time?
send me an email with the data you entered on the form so I can check it out
Reply 867 of 924, by red_avatar
keropi wrote on 2022-04-21, 08:26:
nope it is not possible to do this choice without using the jumpers , the easiest way IMHO to achieve this is to enable CSMPU@30 […]
Hmm I know lots of games look for 330 specifically (because it caused me a ton of issues in the past) so I think I'll just not use the X2GS then with the Orpheus. I either use Adlib or OPL3 or SC55 or MT-32 in 95% of all cases anyway so the X2GS wouldn't have been used all that much except in games that don't have MT-32 or SC55 support but do support Wavetable (and how many games are like that?).
I'll just add it to my Pentium II PC then - perhaps it makes more sense there anyway since the later games that support General MIDI wouldn't run well on my 486 DX2 66 anyway.
I do have another question: SoftMPU would fix the MT-32 timing issues which on faster PCs would cause the MT-32 to not work. Does the Orpheus include this fix as well? Older Sierra games especially need it to initialize the MT-32.
Retro game fanatic.
Reply 868 of 924, by keropi
I can only think one GM game that does not offer port selection, Prisoner of the Ice ... maybe there are more but the vast majority has no issue with port 300
PCMIDI has no "speed control" like softmpu - it is like the original Roland and MQ cards of the past.
The solution is to slow down the whole system, with my 233mmx build I just use ICACHE and it works fine - not sure about a pentium2 system though - there is no such utility AFAIK
Reply 869 of 924, by red_avatar
keropi wrote on 2022-04-21, 10:02:
Well the Orpheus is to go in the 486 DX2 but Sierra games go wonky the moment you go above a 386 - slowing that down doesn't fix all games (I can only get it down to the speed of a 486 SX 33 with any utility I tried). The X2GS will get added on the soundcard in my Pentium II.
Can I still use SoftMPU if need be or are the two incompatible?
Retro game fanatic.
Reply 870 of 924, by keropi
never tested the pcmidi/softmpu combo tbh 🤣
what sierra games go crazy? I am curious now
Reply 871 of 924, by Boohyaka
mmh yep, I really don't know what Sierra games you are talking about @red_avatar. I own about all of them and play them regularly on a dx2-66. I'm probably running most if not all of NRS timing fixes I'll grant you that, but I don't see why you wouldn't, and even speed-sensitive arcade sequences are fine on a 486.
Reply 872 of 924, by red_avatar
keropi wrote on 2022-04-21, 11:33:
No worries - I tested all the games that gave the old "failed to initialize hardware" error and they all work fine.
I decided to stuff the card in my Pentium II after all though. I forgot I used a combo of an SB32 and an Audician 32 there (to get OPL3 music) and the functionality of the SB32 is pretty similar to that of the Orpheus but at least I'll have OPL3 on the same card.
Retro game fanatic.
Reply 873 of 924, by red_avatar
Boohyaka wrote on 2022-04-21, 14:14:
Castle of Dr Brain, LSL3, Codename Iceman, etc. all required patches or Softmpu to work on faster machines. The games don't need Softmpu on my 386 however and the sierrahelp website explained why:
http://www.sierrahelp.com/AudioHelp/AudioHard … nErrorHelp.html
EDIT: Just put in my SB16, tried running the same games and I got the error or a black screen as before so yeah, it seems the Orpheus does fix that problem without needing to patch the games. I mean, I know the patches are there but it's always nice when hardware fixes things instead of needing to patch software.
Retro game fanatic.
Reply 875 of 924, by red_avatar
Boohyaka wrote on 2022-04-21, 14:59:
Yup, I've had those dreaded initialization issues on faster machines, but not on my 486 and I'm not using SoftMPU. Not sure why your experience is different
Well it IS a 486 DX2 66 - I haven't tested it on my SX 33 in many years so perhaps the DX2 66 is just too fast while even a DX 40 might not be?
Orpheus DEFINITELY fixes the issue without needing a patch however, nor a slowdown. It's interesting for sure. I'll be moving my Orpheus to my Pentium II now which is DEFINITELY too fast - let's see what it does there.
EDIT Hell yeah: it works perfectly on my Pentium II without any slow down or patch needed. That's amazing! I'll definitely be keeping it in my Pentium II then.
Retro game fanatic.
Reply 876 of 924, by red_avatar
OK after installing Orpheus on Windows 98 I have some more questions:
I installed the Dreamblaster X2GS but while it works on DOS games when I select General MIDI, in Windows I can only select the Crystal MIDI. Is there a way to have MIDI played back in Windows games so that it sounds more akin to a Soundblaster AWE64 (well, like the way it makes MIDI sound in Windows 10 when hooked up via USB)? Or is there a way to play MIDI files to it instead of using the Crystal chip? I discovered the X2GS doesn't work via USB so it would be sad thing for this to also not work ...
Retro game fanatic.
Reply 878 of 924, by red_avatar
Kahenraz wrote on 2022-04-21, 17:27:
You need to install the MPU-401 device driver in Windows. It's not a plug-n-play feature, since it's a genuine MPU-401 device.
Ahah I actually misunderstood the website - that's my mistake. Thanks for the advice. Now to hunt down a driver.
Retro game fanatic.
Reply 879 of 924, by keropi
^ indeed, just add manually the MPU-401 device and you'll get the option to select it for midi playback
windows come already with a MPU-401 driver
X2GS works fine via USB under win10, use something like Tom's MIDI Player to easily select output devices
edit:
unless you are using the CSMPU device for the WT header, you better enable it via the eeprom tool and then windows will install the CS mpu driver
