Reply 20 of 24, by buckeye
- Oldbie
wrote:Are you planning on running ANY DOS games?
If not, then get an Audigy 2 ZS.
For that matter, if you are only planning to run Windows XP, you could even go with a PCI X-Fi card.. not the Xtreme audio which is a lame-duck cut-down version with no hardware acceleration much like how your current Audigy SE has no hardware acceleration.
You mentioned Xtreme audio as a lame-duck, is that the same as the SB X-Fi Xtreme Music? That's what I have for my XP rig and thought it was a good pick.
Intel D865GL Pentium 4 2.4ghz. 512MB DDR 400 Geforce2 GTS 64MB SB Audigy 500W 98SE
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
