First post, by dreamblaster
EDIT: now available at serdashop : https://www.serdashop.com/McFly
A new waveblaster card in the making : McFly
A VS1053 based wavetable synth...
Back to the future with this low end sci fi chip synth squeak DOS game experience
71.43 KiB
57.45 KiB
Thanks for your support !
Reply 1 of 45, by hard1k
Cool! What's about the WaveROM? I don't see any mention of it in the datasheet, nor there is any dicrete on the PCB.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 2 of 45, by dreamblaster
hard1k wrote on 2020-10-04, 21:02:
I also don't know, i think it is very small
Reply 3 of 45, by matze79
a MP3 player ic ?
https://www.sparkfun.com/datasheets/Component … /SMD/vs1053.pdf
Reply 5 of 45, by Kamerat
Neat little board.
darry wrote on 2020-10-04, 22:17:
I wonder if it has any common heritage with the Thunderbird Avenger DSP line from the 90s .
VLSI Solution is another company than VLSI Technology. Philips acquired the latter one in 1999 and it survives as NXP Semiconductors.
YouTube channel
Reply 6 of 45, by darry
Kamerat wrote on 2020-10-05, 00:22:
Thank you. It seems I never got the memo on that .
Reply 8 of 45, by dreamblaster
Mc Fly prototype ready and working,
playing low end midi chip sound !
497.86 KiB
500.37 KiB
Reply 10 of 45, by dreamblaster
A bit of mixed results with this chip, nevertheless it is interesting :
Some tracks sound good, others sound terrible.
I made a recording of 'Aliens ate my railway' from transport tycoon :
https://soundcloud.com/dreamblaster/mcfly-pla … s-ate-myrailway
Reply 11 of 45, by dreamblaster
For some more examples of the sound, check out recordings of Hummtaro's VS1053 based waveblaster board : https://youtu.be/sT3MQPtlaRI
As it uses the same chip, McFly sounds the same as Hummtaro's board.
Reply 12 of 45, by dreamblaster
Okay made the board available in my shop : https://www.serdashop.com/McFly
Cheap module, cheap sound,.. This is a limited batch of 10pcs.
I will only do a next run, if there is sufficient interest.
Reply 13 of 45, by dreamblaster
Where's the swatter ?
818.13 KiB
Reply 15 of 45, by cyclone3d
Welp.. I ordered one as well as a Chill Box.
The recording for Monkey Island 2 is pretty bad compared to MT-32 but whatevs... I probably have some others that sound just as bad.
Next you need one named Doc.
Did you name it the McFly because it sounds like poo?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 16 of 45, by dreamblaster
cyclone3d wrote on 2020-11-04, 19:09:
Tnx !
Because it buzzes like a fly
Maybe if I find another low end chip, I make Biff
Reply 17 of 45, by cyclone3d
What would be really cool is an OPL4 based card. There is a seller on eBay that sells the OPL4 chips but I haven't checked for them anywhere else.
YMF7x4 Guide
Reply 18 of 45, by dreamblaster
DOOM E1M1 : McFly version - it sounds weirds
    McFlyDoomTest.mp3
    3.34 MiB
    90 downloads
