First post, by dreamblaster
Special version of the CHiLL enclosure for DB50XG / XR385 owners...
coming soon !
what color should it be ?
what text ?
    78.7 KiB
OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
S2+X2 special bundle : https://www.serdashop.com/DreamBlasterBundle
Thanks for your support !
Reply 1 of 17, by keropi
looks very nice
but why tie it to one daughterboard? some text covering all would be best?
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 2 of 17, by Salient
dreamblaster wrote on 2020-11-25, 20:42:
coming soon !
I think, just as Keropi says, not to put a specific type as text on it.
Maybe just the General MIDI, General MIDI2 and XG logo's ?
Reply 3 of 17, by Tiido
Home of the full size WB card 🤣
Reply 4 of 17, by cyclone3d
I also have some rather large boards.. so yeah, the text shouldn't be about some specific card.
Maybe call it the "Super CHiLL Box XL" you can always add more random letters if you want... kinda like how the video card makers do.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 5 of 17, by ripsaw8080
Rank DOSBox Author
DOSBox Author
A grille of ventilation holes above the voltage regulator on the interface would be great, as it can get quite hot. Even better would be standoff feet and a lower grille as well. With that kind of passive convective cooling you could stack multiple enclosures with less concern, but it may be asking too much.
Another idea: CHiLL printed on a "front panel" of the enclosure would like nice, and the dot of the "i" being a hole where a MIDI activity LED could go, for one day if/when the interface is revised to support it. 😀
Reply 6 of 17, by dreamblaster
First revision!
    186.75 KiB
    253 KiB
    457.82 KiB
    384.96 KiB
Reply 8 of 17, by dreamblaster
Trelokk wrote on 2020-11-29, 09:40:
Does it also come in black with white (or light grey) letters?
Also: Are there any significant advantages over other enclosures like the Doxbox? How is it powered for example?
it uses the 'classic' CHiLL board (https://www.serdashop.com/CHiLL) which uses 9V DC barrel input
This is a prototype extra-large enclosure, the colors, text,... can still change, depending on your feedback
Reply 9 of 17, by dreamblaster
final revision CHiLL XL
    997.93 KiB
    1.23 MiB
Reply 10 of 17, by dreamblaster
My largest card fits well 😀
Is there any larger card than XR385?
    126.06 KiB
Reply 12 of 17, by Tiido
A leg would be a nice idea.
I'm not aware of anything bigger, this is supposed to be the max size.
Reply 13 of 17, by dreamblaster
Bancho wrote on 2021-02-27, 16:30:
Is it not possible to put some support leg to accommodate the weight of the DB at the far end? Is is just floating on the WT header in your pictures?
yes will add that
Reply 14 of 17, by dreamblaster
New revision, probably this is final
    1.69 MiB
    1.57 MiB
    1.1 MiB
Reply 15 of 17, by dreamblaster
Yeah this is the final revision, available now : at https://www.serdashop.com/CHiLLXL , or pm me
Reply 16 of 17, by dionb
dreamblaster wrote on 2021-03-28, 15:08:
Nice 😀
Before I do so: is it likely the E-Wave will be finished and in the shop soon enough to buy both together (to save on shipping, putting an E-Wave in the CHiLL XL would be the ultimate in unnecessary compensation 😜 )
Reply 17 of 17, by dreamblaster
dionb wrote on 2021-03-28, 20:51:
Nice 😀
that e-wave sure will have enough room
i expect next revision of e-wave to be ready in about 4 weeks. if it is all ok, then first batch would be soon after
