First post, by davide.guida@gmail.c
I've installed an Avance Sound Logic 100 Under DOS 5.00 on a 8086-XT based PC.
Can the joystick port be used? What is the port address number?
Should work. Use UNISOUND to configure it.
I believe port number should be 0x201, but UNISOUND should say what it is assigning the joystick to as you run it.
