First post, by Almoststew1990
I have an Audigy 2 ZS and I don't think it has a front panel header on it for the headphone and mic ports on my case.
If I plug the header into the motherboard's audio will it direct my soundcard'a audio back to the motherboard and to the front panel? Or would I I have to enable the motherboard's built on audio for that to happen (and it wouldn't use the Audigy at all when using the front panel headphones).
It's a 1156 motherboard so I think it's "HD audio" connector rather than AC97 if that makes a difference.
Reply 1 of 3, by TehGuy
The front panel audio connectors generally go into whatever device you want to handle the audio. Motherboard if you want it to do it, soundcard if you want it to do it
Either way, only front panel anything for the 2 ZS I'm aware of is the breakout box, SB0250; I don't think it has AC97 or HD audio connectors.
Win98+DOS: VIA C3 Ezra-T 1.0AGHz, GA-6BXC Rev 1.7 + PowerLeap PL-IP3/T, 128MB RAM, AWE64 + Orpheus, GeForce 2 MX400 AGP, 32GB CF card
PowerMac G4 QS + GeForce4 Ti4200 (with ADC)
Reply 2 of 3, by dr_st
Indeed it does not, but it's possible to make an adapter cable like described here:
http://audigy2zshowto.blogspot.com/2005/05/wa … stroy-your.html
I think some eBay/AliExpress shops may sell such cables.
Reply 3 of 3, by mastergamma12
dr_st wrote on 2021-09-03, 17:56:
Yep, I use that adapter on my X-Fi Xtreme Music to get front panel out on my X58 Lanparty rig.
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
