First post, by smullyoz
Trying to install this card on a WinXP 32bit machine.
Downloaded SBXF_PCDRV_L11_2_30_0004.exe from creative.
The drivers install fine without errors, prompt for a reboot.
However after reboot nothing changes, device manager still shows unknow audio device.
This is on MSI MS-7641 motherboard with the latest chipset drivers.
Reply 2 of 2, by mastergamma12
If you ever use that card in Vista or Later, I highly recommend the UAA Daniel K drivers.
Also just found out that he's done doing the drivers.
F
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
