First post, by Kahenraz
- l33t
I was testing some recordings between different synthesizers and capture devices when I noticed that my SC-55 had an echo to it. I reinitialized it by holding the Instrument left/right buttons, resetting the power and clicking "all" and this made it return to normal. But I don't understand what happened to cause it to change.
I had previously reset my SC-55 and it does not have a battery inside to keep any such changes. I had it unplugged before powering it on for this new recording which had an echo. Unplugging it and powering it on again did not bring the echo back. I also tried changing the default Reverb and Chorus from 40/0 to 127/127 but did not notice any change in how the audio played back.
I did connect this to a computer with an MPU-401 to test some General MIDI playback recently but I would have thought that any setting would have been cleared after the device had been powered down for more than a day.
See attached for both audio recordings of Doom E1M1.
