My 3DMark01 Mega Thread
Reply 20 of 801, by m1919
elfuego wrote:
Interesting fact is that replacing those Xeons with Tualatins 1.4 would literally triple the result. 😄
Yeah... but then it wouldn't be a Xeon rig 🤣.
I'm trying to find a pair of 900/2MB Xeon to swap in.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 21 of 801, by elianda
I don't get this hype to upgrade or overclock a good setup retro PC even more. Usually the system is already good as it is from the retro point of view. If I want a faster system I just pick another CPU from the pile (last estimation 150+) or simply sit in front of my main system. For me it is much more interesting to see comparisons of some stock systems.
Youtube Channel
Reply 22 of 801, by m1919
I like to max out my retro rigs, but I do like to stay true to the original platform I started a build with. So for this rig, it's the 440GX chipset.
Reply 23 of 801, by Standard Def Steve
Interesting rig. Are the 1MB/2MB caches on the Cascades processors on-chip or is it just full speed cartridge-mounted cache? 2MB would've been a monstrous amount of on-chip memory in 2000!
Reply 24 of 801, by m1919
The P3 Xeons up to 550Mhz have full speed off-die cache, P3 Xeons 600Mhz+ have on-die cache of 1-2MB on the 100Mhz FSB versions and 256Kb on the 133Mhz FSB Versions.
Heh, gonna take a cue from luckybob. The 256Kb versions are "Pseudo Xeons" as they're pretty much just regular Coppermines in a Slot-2 package.
Reply 25 of 801, by m1919
Xeon Prime: ASUS XG-DLS, Dual P3 Xeon 700/1MB SL49P, 1.5GB PC100 ECC, GeForce4 Ti4600 128MB, Windows 2000 Pro
Reply 27 of 801, by m1919
sgt76 wrote:
With the same 4600 Ti and a 1.4S Tualatin @ 1.6ghz, I got 9715 marks in 3d mark 2001SE. […]
I wonder how a pair of 900/2MB Xeons would do.
Also, would there be any way to force 3dMark to run on my Obsidian2? I remember seeing someone benchmark a pair of Voodoo2s using it, but I have no options available to let me choose my card.
Reply 28 of 801, by sgt76
By any chance, were they mine perhaps? I used powerstrip to alternate between the AGP card and my V2 SLIs.
3dmark 2000 - 2856 marks (1024x768, 16 bit, default settings)
3dmark 2001se - 1131 marks (1024x768, 16 bit, default settings)
All benches done with Voodoo 2 SLI at an overclock of 95mhz
Reply 29 of 801, by elfuego
Hmm... I must admit that I'm a little disappointed. I expected more from Tualatin. Ah well... I'll stick to Socket A 😀 Thanks for the benchmark!
Edit: BTW, I suppose you did the test with SDRAM (i815)... Can anyone provide a test with dual tualatins or tualatin with DDR or rambus?
Reply 30 of 801, by sgt76
I was using sdram @ 152mhz. ddr apparently won't make much difference as the P3's bus is too slow for ddr bandwidth to be effectively utilized.
Cpu benchmarks is where the Tualatin really shines, performing like a NW 'B' @ 2.8ghz. Anything FPU related, not that hot... maybe like a 1.8ghz Willamette. 😜
Reply 31 of 801, by Standard Def Steve
I don't know if anyone saw my P3-S (i815) result on the first page, but I got 11,312 with a 9800Pro. A Willamette 1.8 (DDR266) with the same video card only scored 9147.
Reply 32 of 801, by elfuego
I heard about this rumor, but I find it still hard to believe. I remember the difference changing from KT133a to KT266a on athlon XP 1600+, the frame rate in Morrowind seemed to double. Thats why I hoped it would be similar on tualatin...
Reply 33 of 801, by Shagittarius
Abysmal Windows 7 i7 920 w/ GTX 690. I didn't see one up so I thought I'd try, terrible results.
I should note that I receive this message at startup:
I get the same message with SLI disabled and I score 37094 that way.
On my C2D 7300 w XP and a GTX580 I get : 47757
Reply 34 of 801, by Mau1wurf1977
Here my i7 3770 + GTX660:
I think 2001 is still the best 3DMark in terms of interesting graphics. It just never gets old. All the new ones are so boring to watch.
My YouTube channel
Reply 35 of 801, by elfuego
I dont understand, do you mean abysmal windows or abysmal i7 920? Or is it GTX690 that's abysmal? Where does the problem lie? 😕
Reply 37 of 801, by Shagittarius
There's nothing wrong with any of the components. Sure the i7 920 is a little underpowered for the 690 but something is wrong with drivers or the benchmark and that particular card it seems. It performs like I would expect in real world applications.
Like I said I tried it un-SLI'ed and it only scored a little more than with which is to be expected.
Reply 38 of 801, by RoyBatty
Win 7 just isn't very good at supporting directx 8 stuff. Drivers are not optimized for it anymore either. I'm pretty sure in XP I got more like 60k vs the 40k I get in win7.
Interesting enough in 3dm2003 I get about 80k in windows 7 =]
