Old games at high-res/60 fps
Reply 20 of 23, by F2bnp
I just realized that Looking Glass Studios' Dark Engine used in the Thief games and System Shock 2 was also a massive hog for CPU time. Minimum CPU requirements for Thief 1 called for a measly P166 in late 1998... yeah right, even a Pentium Pro/II can and will struggle greatly in many areas. I'm thinking the very impressive soundscape didn't make matters any easier. I wonder if using A3D helped any or if it actually added even more load. I could see how they could conceivably accelerate a lot of what Thief was doing on an Aureal chip, but it was probably too much of a hassle anyway.
Somewhat recently, I had an old desktop unit just laying around and I decided I needed to make a quick buck, plus it wouldn't hurt to shift some redundant hardware from the house. It was an i815 board paired with a Pentium III 1GHz and I only really needed to fit it with a video card to sell it as a complete system and the only spares I had laying around were Riva TNT cards. So, I grabbed a Viper V550 and installed it, whilst thinking to myself just how much I was hampering that CPU with this video card. And yet, I was very surprised when I set it up and started doing some tests out of curiosity. Pretty much all of the relevant games from 1997-1999 and even some from 2000 ran particularly great on that TNT, albeit at low resolutions of course, so 640x480 and 800x600.
It was a surprise seeing a lot of games running really well on this, which really drives the point that most of these games were severely CPU limited at the time and even a single Voodoo2 would have been enough for pretty much everything up until a certain point, provided you had a good CPU.
Reply 21 of 23, by swaaye
Rank Moderator
Moderator
Catalyst 7.11 OpenGL also fixes problems with Half Life GotY. And I've found it works for X800 as well as later cards. Maybe R300 cards as well then. I wonder what ATI did to OpenGL with Catalyst 7.12 and later.
Reply 22 of 23, by Srandista
Well, I know, that 7.11 enable table fog, or at least it's first driver, which render fog in Thief 2 correctly. And with 7.12 ATI remove support for some OpenGL extensions (but the fog is still working):
http://www.geeks3d.com/20080623/how-to-run-op … i-catalyst-712/
Socket 775 - ASRock 4CoreDual-VSTA, Pentium E6500K, 4GB RAM, Radeon 9500@9700, ESS Solo-1, Win 98/XP
Socket A - ASRock K7S41GX, AMD Athlon XP 3000+, 512MB RAM, GeForce4 Ti4200, SB Live, Win 98
