Reply 20 of 27, by Srandista
The Serpent Rider wrote:
Old SLI and Crossfire are at least interesting to tinker with. They are not limited to AFR only modes like GeForce 8800+ / Radeon 2900+.
You ma be right, but CF older then HD 2x00 are PITA to use (with exception of X1950 Pro). Dongles and Master/slave cards... Yeah, not really good start from ATI into multiGPU world...
dr_st wrote:
Well, obviously I haven't been keeping track of the developments. 😀 That does, sorta, prove the point - there is little practical (ugh, I'm getting tired of this word) value in supporting SLI/CF in mid-range GPUs, since a single, twice-as-powerful GPU, gives you the same performance, without having to deal with micro-stutter, special optimizations, profiles and other stuff like this, which serves to complicate the already complicated video drivers.
Well, but 386_junkie got a point. If you want to play old DOS game in practical way, then run them in DOSBox... Also, people are not buying convertibles, because they are practical. If you want practical car, you should buy family estate. No, they are buying them, because it's fun. And for the same reason you build SLI/CF system, it's fun. Yeah, there are some obstacles, but you can say the same about any other retro system.
Socket 775 - ASRock 4CoreDual-VSTA, Pentium E6500K, 4GB RAM, Radeon 9500@9700, ESS Solo-1, Win 98/XP
Socket A - ASRock K7S41GX, AMD Athlon XP 3000+, 512MB RAM, GeForce4 Ti4200, SB Live, Win 98
Reply 21 of 27, by Unknown_K
I would use single slot cards to give them some air to breath and nothing too new for that platform so SLI some 7900GTX, 8800GS, 9600GT, etc depending what you can find.
Reply 23 of 27, by chinny22
meljor wrote:
2x dual cards for quad sli.
This was what I thought for a WinXP build for cool factor not practical reasons.
Don't make same mistake as me though
http://nvidia.custhelp.com/app/answers/detail … t-in-windows-xp
Reply 24 of 27, by candle_86
the 7950GX2 quad setup never made any sense, DX9 can only do 3 max rendered frames, meaning the 4th GPU will always be idle, that was the big problem with it for the best SLI option AFR. you need a DX10 GPU and a DX10 OS to make quad make any sense.
Reply 25 of 27, by Skyscraper
Here is another vote for 2x Geforce 7900 GTX. (If you can find any for cheap that is)
If you aim to run XP with SLI and Socket 939 I think it's fitting to use the last (non monstrosity) Nvidia DX9 card as it was released shortly after the FX60 and Opteron 185 (and also pre Vista). There are faster options and I'm normally not the one to insist that builds should be "period correct" but in this case I actually think it should as the build otherwise would morph into something almost modern... Another good thing with the 7900 GTX is that two in SLI will not use more power than a single 8800 GTX...
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 26 of 27, by The Serpent Rider
7800GTX 512mb SLI are 20% cooler. Also 1000% rarer, so bonus points for that too.
Quadro FX 5500 cards are probably even cheaper right now and the best available option from G7x family.
Reply 27 of 27, by candle_86
Or look at old Dells, my 7900GTX's came out of a pair dell XPS's with Core 2 Duo's in them 🤣. The OEM cards tend to be cheaper when they show up, its also how I got my pair of 7800GTX Cards I keep in a drawer, also Dell system pulls, 256mb, but they have the 7900GTX cooler so they run much colder than a normal 7800GTX
