First post, by GadgetBlues
I have a Radeon 9800 Pro that has a screen full of short double vertical lines || overlaying the POST text, each pair about the height of text characters and spaced about 2 characters apart horizontally. It's the same on VGA & DVI.
Does that sound like bad RAM, or do you think it's worth trying to re-cap? There are 5 normal electrolytics, none bulging, and the rest are SMD aluminum.
thanks!
Reply 2 of 2, by The Serpent Rider
Yep, it's memory. And I bet it's infamous Samsung GDDR memory.
