First post, by undeon
- Newbie
Hi everyone,
I've posted a few days about my little protect.
Abit AN7
Athlon XP 2200+ (3200+ on the way)
2x512 DDR400 (2X1GB low latency someday)
Radeon HD 4650 AGP
To power this system I'm using a Corsair CX430 (20A at 5V, the minimal recommended on the manual).
After assembly it, the system started fine and I run memtest86. The memory was OK. Then I removed the Radeon to install a hard drive and the system won't post anymore. The motherboard lcd stops at 25:
Early PCI Initialization:
-Enumerate PCI bus number.
-Assign memory & I/O resource
-Search for a valid VGA device & VGA BIOS, and put it into C000:0
I reseted the bios and tried with a 500W psu (22A on 5V), but without success.
With a Radeon 9600xt happened the same thing, but after a bios reset it worked fine.
I need help because I really want to keep this vga.
Thanks in advance
