First post, by TheMobRules
Hi guys
I've successfully replaced a blown flyback transformer on my old 14in CRT monitor, don't have a lot of experience messing with CRTs but everything went well. My question now is how do I properly adjust the "SCREEN" knob? I have the service manual of the monitor but the adjustment instructions seem to depend on being able to measure luminance and stuff like that, in addition to being somewhat unclear:
(a) Set mode 5 (800x600 Fh: 46.8KHz) full white pattern.
(b) Press hold the Down/Up tow key simultaneously turn on the monitor, the most right four LEDs will
light up for a while then extinguish
(c) Input color adjust factory mode.
(d) Warm up more than 20 minutes.
(e) Brightness set to maximum. Contrast set to minimum full white pattern, then adjust FBT screen VR to
make Y= 1.0FL ± 0.2FL.
(f) Brightness set to raster just cutoff, adjust contrast to beY= 4±0.2FL, then adjust G-Bias, B-Bias, R-Bias,
to make the setting value, then adjust the R.G.B Bias individual to the color temperature x= 283 ± 10,
y= 298 ± 10.
Is there any standard/generic way of adjusting the screen voltage? I don't want it to be perfect, and in fact by randomly messing around a bit with it I've gotten to a point that it looks "good" to me... but I have no idea how far it is from the proper value. I've read about increasing it until raster lines appear on the screen with brightness and contrast at about 50%, but I'm not sure if that's the way to go.
Also, can anyone recommend a good test pattern suite? Something like the 240p test suite but for a PC CRT.
Thanks in advance
