First post, by Pingaloka
Hi people! I've checked the manual for updating the firmware on an Extron RGB-HDMI 300A, from what I can see there are only 2 possibilities:
These are the 2 cables de Extron RGB-HDMI 300 A admits for updating the scaler.
So, my guess we can only update the firmware via an old computer with a serial port?
BTW, the reason why I want to update the scaler is because the image flickers a little bit.
Reply 1 of 5, by RichB93
Serial is the way to do it, either via the TRS cable above, or via the other serial connection on the back of the device; the manual contains pinouts. I made my own cable. You don't need an old computer; a USB to serial adapter works wonders, so it's just a matter of sourcing the software (which still works on Win11). If you contact Extron, they'll be more than happy to help with software.
Reply 2 of 5, by Pingaloka
RichB93 wrote on 2021-12-26, 14:49:
Hey! Thanks a lot for the tip! DO you think there could be any beneficial effects on the image video processing of the Extron RGB-HDMI 300A by updating the firware?
Reply 3 of 5, by RichB93
There could be, depending on how old the current firmware is. Do have a play with the settings, even after doing the auto setup on the image - doing some improved the image quality for me when capturing from a 3DFX card.
Reply 4 of 5, by Pingaloka
RichB93 wrote on 2021-12-26, 18:05:
Yeah. I've been fiddling with It for the last couple of days and improved image a lot. I use It for capturing DOS footage. I'll check the firmware update info and maybe I'll try and see if there is any improvement at all.
Reply 5 of 5, by NyLan
Hey,
the manual is not very clear on this point. It's just stating RS-232 but when I search for usb to rs-232 adapter most of them are rs-232 TTL adapters, and I believe that TTL and RS-232 are actually different, or may I go ahead with a RS-232 TTL adapter ?
Thanks
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
