Reply 20 of 113, by Stryker1996
- Newbie
imi wrote on 2022-06-13, 02:15:idk where to even begin with this one :D […]
Stryker1996 wrote on 2022-06-12, 18:51:imi wrote on 2022-06-12, 17:25:you can get a reproduction made in russia though and even that will cost you like over $1k
How would recreating it cost $1000 if there are cards now that are about 1000x faster.
idk where to even begin with this one 😁
...but I will try:
- sourcing an original V5 6000 to base the design off
- reverse engineer the original card
- engineering a new schematic and board and getting them manufactured probably going through multiple iterations on a small scale
- sourcing the components, especially the 3Dfx chips
- software developement to make them actually work
there are so many hours involved in a project like that and it's a tiny production run, of course it's expensive.also you know you can reply to multiple posts with one reply, right?
I'm not sure if we're being trolled or not.
Oh, it's an exact reproduction with the exact same components, I just found an image but I couldn't find the store where you can buy it from.
