Jill of the Jungle Sound Effects
Getting old DOS games working on modern hardware. (DOSBox topics belong in DOSBox areas below, not here).
Re: Jill of the Jungle Sound Effects
Postby NewRisingSun » 2017-5-16 @ 18:04
I never noticed that the lava was supposed to be animated, having used v1.2d as a reference before.
It's definitely something in the original v1.2d executables. I have a distribution that has both v1.2b (as JJFILE1.EXE) and v1.2d (as JJFILE01.EXE) in the same directory. JJFILE1 (v1.2b) has animated lava, JJFILE01 (v1.2d) has not. That version is even more broken than I previously thought. If v1.2b and v1.2c did not have that hideous timer-driven sample playback routine, I would consider making a patch to downgrade from 1.2d to 1.2c.
Oh well, another issue to investigate....
NewRisingSun
Postby K1n9_Duk3 » 2017-5-16 @ 22:14
I'll save you some time and tell you what caused the issue:
For some odd reason, the compiler that was used to build version 1.2d did something wierd. Basically, the original code used to be
Code: Select all
setboard(x, y, bd[x][y] | ((msg_block(x, y, msg_update)!=0)*mod_screen))
and the compiler decided it was a good idea to read the value from bd[x][y] before calling msg_block(), which updates the value at bd[x][y] with the next frame of the tile's animation cycle. So the tile number is reset to its previous value immediately after it was updated and you never see the animation.
The code in question was "updbkgnd()" in "JMAN.C" (starting at seg022:120F when I open the executable in IDA Freeware 5.0).
I recommend replacing the code with something resembling this:
Code: Select all
if (msg_block(x, y, msg_update))
   setboard(x, y, bd[x][y] | mod_screen)
I used the names from the Xargon source code and the debugging information from the Jill executable itself. If you don't want to look up the values for msg_update and mod_screen yourself, here you go:
Code: Select all
msg_update = 2
mod_screen = 0xC000
There were some other issues in v1.2d that prevented the screen from updating when some tiles were changed by a trigger or a switch. I don't know if you already fixed that. The issue is caused by calling the setboard() function without the "| mod_screen" part. I think the call at seg015:2715 is responsible for this, but it might be hard to add the "| mod_screen" there just by hacking the executable.
User avatar
K1n9_Duk3
Postby NewRisingSun » 2017-5-17 @ 04:08
Thank-you. That should help a lot.
K1n9_Duk3 wrote:and the compiler decided it was a good idea to read the value from bd[x][y] before calling msg_block()
As I understand the C standard, the order of evaluation in this case is undefined, so the programmer was wrong to assume a particular order.
K1n9_Duk3 wrote:and the debugging information from the Jill executable itself
Did you get IDA FW 5.0 to make use of that debugging information?
NewRisingSun
Postby K1n9_Duk3 » 2017-5-17 @ 05:28
No, I did not manage to get IDA itself to use the debugging information. I have written a tool that extracts C-style strings from binary files (basically just replacing any 0 bytes with line breaks) and used the resulting text file and the Xargon source code to assign the names of functions and variables in IDA. I should also mention that I used an older freeware version of IDA for the initial analysis of the executable, since that version can detect compiler signatures and will assign the correct names to the runtime library functions.
The Xargon source code does not contain the source files for all parts of the game, though. Some files are only included as .OBJ files in Xargon, like the low-level graphics code in GRL.OBJ and GRASM.OBJ. Opening these in IDA will make use of the names stored in the .OBJ file, but I guess you already know that.
User avatar
K1n9_Duk3
Postby NewRisingSun » 2017-5-17 @ 18:03
K1n9_Duk3 wrote:The issue is caused by calling the setboard() function without the "| mod_screen" part
But how could that part have disappeared when recompiling the game?
I think I have fixed the lava animation and switch-flipping screen update issue in all three executables at the locations that K1n9_Duk3 mentioned, and from what I can tell, they seem to work correctly now. But have not had the time to play through the games again. I am posting this as a "-TEST" patch until someone who has tested it more extensively tells me that I can replace the main patch with it. Install JILLUPD-TEST instead of JILLUPD on an unpatched game distribution, and apply EPICFM on top of it if you wish.
Edit: Patch updated in the latest post.
NewRisingSun
Postby K1n9_Duk3 » 2017-5-17 @ 20:47
In the Xargon source code, there is a macro definition for setboard():
Code: Select all
#define setboard(x,y,n) bd[x][y]=n|mod_screen;
My guess is they replaced the macro with an actual function in v1.2d (the setboard() function checks if x and y are in range, to avoid memory corruption). The older versions probably used this macro since I cannot find a setboard() function in them.
User avatar
K1n9_Duk3
Postby SaxxonPike » 2017-5-18 @ 16:26
Thank you both so much for your work on this bug. I'll play through them and let you know. It's especially good if this also fixes the issue where using switches for platforms that are within the viewport don't update on screen. The two problems likely have the same cause in the D release of the game. Time to confirm :)
User avatar
SaxxonPike
Postby James-F » 2017-5-19 @ 05:13
I have tested ver C and there are no bugs with Water/Lava/Switches.
But ver D (episode 1 shareware) has all three animation problems.
I don't have 1.2D trilogy, so I can only attest for 1.2C trilogy.
User avatar
James-F
Postby SaxxonPike » 2017-5-20 @ 22:38
I'm happy to report everything is working great with the latest patch, animations and all.
User avatar
SaxxonPike
Postby NewRisingSun » 2017-5-21 @ 06:46
NewRisingSun
Postby SaxxonPike » 2018-5-17 @ 03:58
This version of the game, whichever it is, allows Jill to kill demons in one hit. Wonder if this was the intended behavior?
https://www.youtube.com/watch?v=dJZaSy3hwvk
I know in 1.2d they are SUPER difficult.
User avatar
SaxxonPike
Postby K1n9_Duk3 » 2018-5-19 @ 22:10
Probably a hacked version of the game as far as I can tell.
What I can say for sure is that the demon code in version 1.0 of JILL1.EXE differs slightly from the code in v1.2d. In v1.0, any weapon can hurt the demons, not just the spinblade. Also, since the executable is uncompressed and contains debugging information, it's easy to find the code for the demons and modify the amount of hits a demon can take before it dies. Since the demon has 5 hit points and 4 frames of invulerability between hits in both the earliest and the latest version of JILL1.EXE, I doubt that it would be any different in other versions.
Correction: Nope, it's not hacked, just the normal behavior in v1.0 that I didn't notice at the time I wrote this.
User avatar
K1n9_Duk3
Postby SaxxonPike » 2018-5-23 @ 02:10
The one hit kill demon thing happens in whatever version of the game they're using:
http://tasvideos.org/5779S.html
Filesizes and hashes are listed here and they touch on it in the section where they cover Level 9. I'm really curious what exactly is going on here...
Edit: The demo in Level 9 in Jill 2 also makes more sense with demons taking one hit. I don't have a legitimate 1.0 to verify (only original I have is 1.2c from the B&N release which has the difficult demons)
User avatar
SaxxonPike
Postby K1n9_Duk3 » 2018-5-23 @ 21:00
After seeing the file size of JILL2.EXE on the page you linked to, I had to compare it to the known versions on the ModdingWiki: http://www.shikadi.net/moddingwiki/Jill_of_the_Jungle
Whatever version was used in the speedrun is definitely not listed on the ModdingWiki page. And as you can see, I was wrong about the executable being uncompressed, at least in the case of the earliest versions of Jill 2. I still think it's a hacked version or perhaps even a beta version, which would explain the weird demo you mentioned. But it could also be possible that the original release of Jill 2 had demon code that differed from the code in Jill 1, and that the modified code was accidently removed when they updated the code for the later versions. Given the animated tile issues that appeared in v1.2d, this wouldn't surprise me at all.
Without access to the JILL2.EXE from version 1.0, there's not much else I can say about this.
User avatar
K1n9_Duk3
Postby SaxxonPike » 2018-11-02 @ 19:30
For those of you who have waited for a legal online distributed version of this game, it looks like GOG has just released the whole trilogy for free today:
https://www.gog.com/game/jill_of_the_ju ... te_trilogy
It looks like the game versions are (based on CRCs):
Volume 1 - v1.0
Volume 2 - v1.0 (but they didn't compress it with LZEXE this time)
Volume 3 - v1.2b
User avatar
SaxxonPike
Postby K1n9_Duk3 » 2018-11-03 @ 22:15
Yeah, I already had a quick look at JILL2.EXE from the GOG release since the demon can be killed with one hit in that version. The demon code is identical to the code I saw in v1.0 of JILL1.EXE, meaning that it actually needs to take more than 5 points of damage before it dies. I honestly had no idea why it's possible to kill the demons with one hit in this release. I even wrote a program to check of the demon objects are basically pre-damaged in the level files and found out that that's not the case.
But as I was typing this, I had a look at the code for the spinblade weapon. The spindblade is coded to instantly kill any object that has the 0x400 flag set. And sure enough, the demon has the flags 0x400 and 0x80 defined in version 1.0. So even though the demon code expects the demon to be hit 6 times to kill it, the code of the spinblade weapon bypasses that check. In version 1.2(d), the demon has absolutely no flags set, which explains why it takes 6 hits to kill in the later releases. Mystery solved.
User avatar
K1n9_Duk3
Postby badmojo » 2018-11-04 @ 22:41
SaxxonPike wrote:For those of you who have waited for a legal online distributed version of this game, it looks like GOG has just released the whole trilogy for free today
Thanks for posting this, I was looking for a legal version a while back and had no luck so am very happy to have picked it up for free!
If it's broke, then fix it!
User avatar
badmojo
Postby NewRisingSun » 2018-11-07 @ 17:32
So is the version of the game to which my patch updates the most desirable one in terms of demon damage behavior, or is a modification in this regard desirable?
NewRisingSun
Postby SaxxonPike » 2018-11-08 @ 18:10
K1n9_Duk3 wrote:Yeah, I already had a quick look at JILL2.EXE from the GOG release since the demon can be killed with one hit in that version. The demon code is identical to the code I saw in v1.0 of JILL1.EXE, meaning that it actually needs to take more than 5 points of damage before it dies. I honestly had no idea why it's possible to kill the demons with one hit in this release. I even wrote a program to check of the demon objects are basically pre-damaged in the level files and found out that that's not the case.
Fascinating! Thank you for investigating this.
I'm really curious what the original intent was. I wonder if we'll ever get to know. I would love to believe that the 1.0 release was the original intent and careless bugfixes just happened to break the demon functionality. But for all I know, instantly killable demons was a bug itself.
EDIT: I asked Tim on Twitter (@TimSweeneyEpic):
https://twitter.com/TimSweeneyEpic/stat ... 9625185280
"I don’t remember the balancing tradeoffs, but they arose because I finished tuning episodes 2 and 3 after episode 1 was released."
User avatar
SaxxonPike
Postby NewRisingSun » 2018-11-09 @ 15:11
My interpretation of this statement is that the spinblade should in fact kill demons instantly in Episode 1, but not in Episodes 2 or 3. It is not unheard of in gaming that the same enemies become harder and more powerful as the game progresses.
NewRisingSun
PreviousNext
Return to DOS
Who is online
cron
