Reply 20 of 25, by PeterLI
My suggestion would be to find an OEM Pentium I / II with ISA slot(s) for DOS games that require true SB. Good luck! 😀 Eventually one will pop up: even in Peru.
I agree, try to find a P1 or p2 machine. This will solve a good portion of your woes by letting you use a real SB card.
Check me out at Transcendental Airwaves on Youtube! Also wtf, why are whoppers so good?!
I'd be careful choosing a Yamaha. It is true it has genuine opl3 synth, but the Mobo compatibility is really lack luster and even the sblive is probably better. I suggest you choose the vortex 2 if you will play both windows and dos games (and don't care about opl3), or the ESS solo if you only care about DOS and want good opl3; ESS solo also has an sblink header if your mobo has one (I think it's removed on some solos).
wrote:Also it's never a PCI card that's going to be recommended for DOS, so your computer is null and void for any "best DOS soundcard" since all the best ones are ISA.
I have a P2 board that has YMF715E onboard (AL440LX), technically on an ISA bus, that count? :p
PC hardware: Dell Latitude E6440 | 16GB RAM | 500GB 850 EVO SSD | Core i5-4310m
Audio hardware: Sony STR-DH500 5.1ch AV receiver | Minimus 11 front and rear channels | Minimus 7 center channel, connected with 14ga wire.
I have a Compaq en. When I tried to install a vortex 2 sound card in win 98se I got "not primary pci slot" I got this error in every pci slot. Installed a sb live! And it worked like a charm. I've had horrible results with installing vortex 2 cards. Particularly the diamond monster. Some PC ' it install fine but with many I find it causes windows to freeze up right after the desktop comes up. It seems to happen mostly with VIA chipsets.
wrote:I have a Compaq en. When I tried to install a vortex 2 sound card in win 98se I got "not primary pci slot" I got this error in every pci slot. Installed a sb live! And it worked like a charm. I've had horrible results with installing vortex 2 cards. Particularly the diamond monster. Some PC ' it install fine but with many I find it causes windows to freeze up right after the desktop comes up. It seems to happen mostly with VIA chipsets.
You just have to take a ; off of "detectprimarypcislot" or something like that to fix the Primary PCI slot issue in a installation ini. Should be easy enough to Google the correct wording.
