Reply 160 of 166, by ericvids
- Newbie
Pickle wrote on 2022-05-11, 12:21:maybe you could include it but keep off by default and allow these extra features to be enabled by command line?
You mean include the fullscreen option (without status) on the MPU-only version but make it hidden? I mean, it's already technically included AND off by default (because you have to select your view size in Change View), but is hiding it and enabling it only via command line a necessary step in your opinion?
Note that I also already have a hack to the config file so that the vanilla EXE can still run properly even if the user selects the fullscreen view size on the wolfdosmpu EXE, so there's no worry of accidentally "breaking" things for the user.
Gmlb256 wrote on 2022-05-11, 12:48:The fullscreen on the MPU-401 version can be kept barebones and the users can be warned that they won't be able to see the stats.
I'm leaning towards this solution, since it obviates the need for a command line option, and it's helpful to the user...
