First post, by u1comp1
Installed Windows 10 x64 Enterprise 1709.16299.192. In the Tomb Raider Legend, the sound is cracked and interrupted. Sound Card Creative Sound Blaster X-Fi Titanium Fatal1ty Professional SB0886. Drivers are installed the freshest. Is there any solution to this problem?
Reply 1 of 1, by u1comp1
The problem was solved! You need to take the files from Creative Alchemy: dsound.dll and dsound.ini and put them in the game folder. In the dsound.ini file, you need to change the value of duration = 25 to duration = 10
