First post, by filipetolhuizen
According to this: http://www.tm-forum.com/viewtopic.php?t=24517 TMS doesn't like 8GB RAM. You need to have more or less for the game to work on Win64 and I just stumbled across this same issue. Limiting Windows memory on boot works fine, but I'm looking for something more definitive. I already tried fixes for limiting the memory to 512mb and 2GB in MS ACT but they didn't work. Anyone else has a better solution?
Reply 2 of 6, by mrpenguinb
TrackMania Original bugs out when your system has an unusual amount of memory (as far as I have tested, I don't have the definitive answer). Using a DirectX wrapper solves the white screen issue in TMO. Not sure if it would help fix yours or not.
Reply 3 of 6, by Davros
You could also try a ramdrive
https://www.tekrevue.com/tip/create-10-gbs-ram-disk-windows/
you could also try Resplendent Resolver (ive not tried it with win 10)
https://www.resplendence.com/resolver
Reply 4 of 6, by filipetolhuizen
That did the trick for TMS (using dgvoodoo2) without any noticeable performance degrade. Thank you very much!
Reply 5 of 6, by mrpenguinb
No problem! TMO has similar issues to TMS (they use the same fundamental engine) However, I can't get TMS running on Windows 10 even when disabling driver enforcement for StarForce to work. The game still doesn't like my system (unfulfilled system requirements).
Reply 6 of 6, by filipetolhuizen
Most of these outdated copy protection systems won't work properly on Win10 wihtout some extreme workarounds, and most still doesn't work at all.
