First post, by Nippon
Hello
when i start the game, allways crash back to desktop.
How can i Play Blade Runner ?
Reply 1 of 8, by Srandista
Run it through the latest ScummVM.
Socket 775 - ASRock 4CoreDual-VSTA, Pentium E6500K, 4GB RAM, Radeon 9500@9700, ESS Solo-1, Win 98/XP
Socket A - ASRock K7S41GX, AMD Athlon XP 3000+, 512MB RAM, GeForce4 Ti4200, SB Live, Win 98
Reply 3 of 8, by imi
it's the game engine: https://en.wikipedia.org/wiki/SCUMM
scummvm lets you run it on modern platforms: https://en.wikipedia.org/wiki/ScummVM
since you didn't really supply any information in your original post on what you're trying to play it on, giving a more useful answer is hard.
Reply 5 of 8, by Mr.Blade
Hi, I'm dev of the Blade Runner Installer.
Delete the ddraw.dll in your game directory and launch the game via BLADE.exe --> this should work.
Currently, aqrit's ddraw wrapper doesn't work anymore. I need to find an alternative to emulate a refresh rate in ddraw mode.
Maybe ScrummVM is now the better choice.
Reply 7 of 8, by skitters
Read over the instructions here:
https://wiki.scummvm.org/index.php?title=User … VM#Blade_Runner
You need to copy files from the game CD's to a folder on your hard drive. Copy the files listed here for the German version:
https://wiki.scummvm.org/index.php?title=Blad … rman_CD_release
Rename the cdframes files or alternately use the "pack_bladerunner" tool that is linked to in the instructions at https://wiki.scummvm.org/index.php?title=User … VM#Blade_Runner
Then start up ScummVM, choose Add Game, and browse to the folder where you copied the files. ScummVM should detect the game.
Do you know what is to set on Options, […]
Grafikmodus
Rendermodus
Skalliermodus
Leave that stuff alone until you've got the game running.
