First post, by dnewhous
With DosBox -X "Bad command or filename - 'WIN'" when I try to run setup.exe.
Daniel L Newhouse
Reply 2 of 5, by Discrete_BOB_058
dnewhous wrote on 2021-04-14, 16:35:
If setup.exe is a 16 bit executable, try to run it using OTVDM
YouTube Channel:
Sapta Debuggs
PC SPECS:-
CPU: AMD Ryzen 5 1600
GPU: ZOTAC NVIDIA GeForce GTX 1050Ti OC Edition
RAM: 8GB*2 Corsair Vengeance LPX DDR4 2400MHz
Motherboard: Gigabyte Aorus B450M
PSU: Corsair VX550
Sound Card: Realtek ALC892
Reply 4 of 5, by dnewhous
Doesn't DOSBox -X run Win9x games? Even if Windows doesn't.
I've used network over LAN. I have read the network over WAN works too, if you have one person with Windows server edition.
The online manuals for this game are illegible.
Daniel L Newhouse
Reply 5 of 5, by Jorpho
dnewhous wrote on 2021-04-15, 20:15:
As I already wrote, in this case setup.exe is a Windows 3.x application, not a "Win9x game". And in any case DOSBox-X isn't going to run anything related to Windows (either Windows 3.x or Win9x) unless you install the relevant version of Windows in DOSBox-X.
BoxedWine and OTVDM run Windows applications without a Windows installation.
I have no idea what this is supposed to with Master of Orion 2.
That PDF is entirely legible if you zoom in.
