First post, by Muz
How to disable prefetch in Windows?
Reply 1 of 3, by eL_PuSHeR
Rank Moderator
Moderator
Which Windows version?
For pre-w10 Windows you open regedit and navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters
And you have two keys: EnablePrefetch and EnableSuperfetch; with the following values:
0 - Disabled
1 - Enabled (boot only)
2- Enabled (applications only)
3- Enabled (boot and applications) [default]
For w10 onwards open either services.msc or an administrative cmd.exe window and disable either Superfetch/SysMain service.
For command-line: sc config Superfetch start=disabled
sc config SysMain start=disabled
and reboot.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
