80286 test suite?
Emulation of old PCs, PC hardware, or PC peripherals.
80286 test suite?
Postby rfka01 » 2019-9-17 @ 11:47
Hi folks,
which features would you test / what programs would you throw at an emulator to make sure it's working as best as possible?
I'm not after graphics tests, just the motherboard emulation.
Robert
rfka01
Re: 80286 test suite?
Postby superfury » 2019-9-17 @ 19:27
There's the Landmark/Supersoft AT Diagnostics BIOS? (Supersoft/Landmark Diagnostic ROMs for IBM 5150/5155/5160/5170)
That tests parts of the motherboard(and a large part of the CPU(except it's instructions).
There's also CheckIt! Diagnostics for MS-DOS which does a simplified version on the protected mode part(as well as DMA and Interrupt Controller with it's system board tests). It also has some more tests for keyboard(8042+Keyboard) and video adapter(although that probably uses the video BIOS expansion ROM instead). And of course other tests(PIT timer vs CMOS time check in it's CMOS clock test).
For 80386+ there's also the test386.asm test suite, which does a bit more extended instruction, protected mode, paging, some system instructions(no protected mode interrupts, stack checks etc. yet unfortunately).
Unfortunately CheckIt currently refuses to run on my Pentium emulation, even though it's a superset of the correctly functioning(afaik, since it runs checkit in real mode(non-V86 mode) correctly. It will currently only run on the Pentium emulation using a Virtual 8086 mode monitor(like JEMM386, QEMM or EMM386), but crash with a literal INT 0h in real mode(which is kind of odd, especially since it shouldn't use Pentium-specific instructions afaik).
superfury
Postby rfka01 » 2019-9-18 @ 10:50
Good idea re. the Landmark/Supersoft ROM and Checkit. I also remembered the Diagnostics disks for IBM.
Later 80286s will have memory expansion features, but I need to look up what in terms of XMS/EMS et al. is possible ... and how to test it. It's been quite a while since that was relevant :)
Robert
rfka01
Postby superfury » 2019-9-18 @ 13:50
XMS also uses LOADALL to do it's work(himem.sys) on a 80286. Not on the 386 though(new protected mode switch mechanism). Don't know of EMS managers on a 286 though.
superfury
Postby crazyc » 2019-9-18 @ 20:01
286 can't emulate EMS like the 386 can so it's only available with an EMM adapter like for XTs or a chipset that has built in support like the NEAT.
crazyc
Postby superfury » 2019-9-18 @ 21:33
That explains why I don't know of any XD And indeed, Virtual 8086 mode is required to emulate EMS using XMS properly, so it can't be done on a 80286. Hi(gh)mem(ory) blocks moving can still be done on a 80286(using LOADALL), but that's about as far as it can go I guess(although, on such a CPU, protected mode would be more efficient(any return to real mode using a triple fault). That's probably why Windows uses protected mode by default on such a CPU?). So with a 286, LOADALL-enabled unreal mode or full-blown 16-bit protected mode is as far as you can go with using more than 1MB of RAM(Actually less, due to RAM remapping for hardware devices(VGA,BIOS ROMs, option ROMs in the A0000-FFFFF range).
superfury
Postby Jo22 » 2019-9-19 @ 15:50
I second that. While there's EMM286, it's not the same as EMM386. Like most LIMulators,
it uses XMS and copies memory back and forth instead of remapping memory pages.
Back in the 1980's there also were LIMulators that used the fixed disk for swapping memory in and out.
These were useful for slow programs, like Lotus 1-2-3 and such. Anyway, you guys likely know this already.
What's not so popular - There were external MMUs for 286 systems (some sort of daugther cards).
I don't know about the details, but PC-MOS/386 docs mentioned such stuff.
User avatar
Jo22
Postby rfka01 » 2019-9-21 @ 09:55
Thanks for the memory refreshers and explanations, folks!
rfka01
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 4 guests
