No CRT Emulation? Why!?
Reply 120 of 122, by Deffnator
Its possible to use CRT shaders on DOSBOX of late thanks to Dosbox ECE and X supporting it, also reshade got a boost with more CRT shaders from retroarch being backported like royale, and i think crosire is working on making its support better for the next major update.
seeing them ported to it and even working on DBGL if it gets a shader update for it, would be the perfect mix.
Also
https://github.com/tyrells/dosbox-svn-shaders and https://krystof.io/dosbox-shaders-comparison- … s-retro-gaming/
Reply 121 of 122, by appiah4
I wish someone would start a DOSBOX for with these shaders.. I want to use this but I am too lazy to get ECE and set this up myself 🤣
Reply 122 of 122, by Jo22
appiah4 wrote on 2021-10-12, 06:25:
And I wished someone would integrate cool-retro-term into DOSBox.
Would definitely improve the visuals of Hercules emulation.
- And monochrome CGA, too. Some XTs had on-board CGAs with an RCA connector installed at the back that carried Luma only.
572.67 KiB
Source: https://steemit.com/technology/@crypticwyrm/c … macos-and-linux
