First post, by Jolaes76
...a probably dump question:
how does one know whether Winamp is using a soundfont loaded under Awe32 control panel (as default general midi synth) ?
When GM MIDI files are playing in Winamp, I can hear no difference whatever soundfont I load... 😕
The default windows 98 midi port is AWE32 620h for single inst.
Winamp is set to that output as well.
The emulated MPU-401 at 300h cannot be selected in Winamp as output; Winamp only sees physical devices.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
