Reply 140 of 181, by Osprey
Yeah, I didn't mean that it's more accurate, just that the fuller sound suits my taste more. I did check out someone's Doom soundtrack recorded on the SC-55 and he actually makes it available in both "raw" and "boosted" versions (here). The raw version is, presumably, with all settings on the front panel at their defaults, and the boosted version with them kicked up a few notches. In the end, you might argue that the raw is more "accurate," but I suppose that you could argue that they both are, since the SC-55 was designed to be fiddled with to get the sound that sounds best to you, which is why it had settings like level and reverb right on the front panel. I wasn't arguing one way or the other, though. I was simply sharing my impressions of the differences between deemster's version and the re-balanced one to help others decide which would be more to their tastes.
