First post, by sliderider
Does anyone know of any Virtualization/Emulation software for PPC Macs that will utilize whatever video card you have installed instead of emulating one? Virtual PC and Guest PC emulate only a 2D video card (usually a Cirrus Logic or some other 2D chipset) and do not use the card installed in the system. I want to use it to play 3D games. I know about DOSBox, but that doesn't also allow for the running of Windows and non-game apps.
Reply 1 of 4, by superfury
Are those video cards of a Mac even available on PCs unmodified? If there's no drivers and/or compatibility for the cards in PC software, it's useless anyways?
UniPCemu Git repository
Reply 2 of 4, by kjliew
Utilizing real hardware from virtualized/emulation environment is not an easy feat, unless the underlying hardware generate no interrupts or DMA operations, which isn't the case for video cards. Several technologies have been available, such as SR-IOV, IOMMU, EPT etc. to assist software to do so for x86 systems. The Mac ecosystem is no longer centered on PPC, so I doubt it will get any of such technologies to enable virtualization/emulation to use real hardware.
Reply 3 of 4, by DosFreak
You mention VPC, 3D games and Windows so I'm assuming you are talking about trying to run Windows 9x x86 D3D/OGL/Glide games on a PPC mac.
CPU would require alot of overhead so emulation of the GPU wouldn't be usable. Hardware doesn't support vt-d so no passthrough.
The only possibility would be by utilizing a wrapper but you'd have to determine what the minimum PPC CPU would be needed as well as the minimum video card for playable performance and then either code a custom emulator or more likely utilize DOSBox or qemu with some modifications.
IIRC, VPC 3.0 emulated a Voodoo card back in the day but it was far from ideal.
Really if you have to play x86 3D games on PPC you'd be better off with someone designing a PCI card with the CPU and video card built-in like they did back in the day but if you're going down that route you may as well just use a PC.
Make your games work offline
Reply 4 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Judging by how weak the PPC Macs are when using them to emulate DOS, emulating more is really asking for a slideshow.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
