First post, by Muz
When I try to imgmake, in DOSBox Daum, for example, imgmake windows95.img, etc, I can't find the img file in the DOSBox Daum folder, where is it?
Reply 3 of 3, by Jorpho
That depends entirely on what you specifically need to do, and why you need to use "Windows 95 emulation" instead of just running software directly in Windows 10 (or whatever version you're using).
