First post, by superfury
Is there a way to make Windows 10 see a serial port, which is connected using Dosbox's TCP connection-based nullmodem with 0xFF escapes for RTS->CTS and DTR->DSR/CD connection?
UniPCemu supports it now, but I want to use software on Windows 10 (mainly NT4 kernel debugger using said COM port) to communicate with UniPCemu's running kernel using said connection? Does software using that kind of TCP connection exist?
So pretty much the Dosbox serial nullmodem port emulation only for m0dern Windows?
UniPCemu Git repository
