Reply 20 of 50, by Mau1wurf1977
I believe Quake was one of these games that used Intel instructions to peform better. Other cpus like the K6 and Cyrix would struggle with these type of applications.
Nice cooler!
My YouTube channel
Reply 21 of 50, by Tetrium
Just FYI, I'd just get the fastest K6-2 2.2v for as cheap as you can buy. They are abundantly available and should be CHEAP!
The 350 and 300 parts are just less overclockable versions of say the 450 and 500 parts 😉 (except the newer ones will be CTX core, newer versions slightly better overclockable and supporting 6x multi)
The K6-2+ and K6-3+ are basically die schrinks of the standard K6-3 (with the K6-2+ having half the cache disabled, I presume)
My retro rigs (old topic)
Report spammers here!
Reply 22 of 50, by DonutKing
Not just Quake but other 3d games as well. Its due to the lower floating point performance of the AMD/Cyrix CPUs- they were focused on fast integer performance which is important for desktop/office/multimedia type tasks. This is what gave them higher clock-for-clock performance for these tasks and in benchmarks- but when it comes to gaming, the Intel processors were king right up until the Athlon came out. Floating point performance is critical for 3d gaming.
I had a Cyrix 6x86 PR166 and although it was quicker on the desktop, in 3d games like Quake and others, it was slower than a Pentium 120. The had an even weaker FPU than the K6.
I knew the Pentium would be faster in Quake clock for clock but I'm surprised that its lead is so large, even with a 100Mhz advantage the K6 can't beat the Pentium.
RG100 if you do some synthetic benchmarks like Sisoft Sandra, see if you can disable 3DNOW somehow- I predict that you will see the floating point performance is significantly lower than the Pentium. Very few games of this era took advantage of the 3DNOW instructions.
Reply 23 of 50, by Mau1wurf1977
What a shame, as during my FSB scaling tests without L1 cache I found that the 6x86 chips are the fastest Socket 7 cpus you can get...
My YouTube channel
Reply 24 of 50, by ratfink
Mau1wurf1977 wrote:
There is even a config.sys driver where you can set the CPU multi when you boot the machine 😀
I recall having had a utility to change the cpu settings [multiplier, maybe others] on the fly with k6/2+ and k6/3+ chips.
Reply 25 of 50, by Mau1wurf1977
Sorry I forgot to mention that the config.sys tool is for DOS. For windows there are "on the fly" tools but I am unaware of such a tool for DOS...
My YouTube channel
Reply 26 of 50, by DonutKing
Yes, the K6/6x86 always did well in synthetic benchmarks... I suspect that 3Dbench, being rather primitive low resolution 3d graphics isn't FPU intensive, as evidenced by the 486SX25 giving almost equal performance to a 486DX25 in your 3dbench database.
I've got a 386DX board here and a 387 copro to go with it... maybe when I get a chance I'll try 3dbench with and without the copro installed and see if there is any difference. Another thing to add to the 'to do' list 😜
In my own testing with 3dbench, it seems to be more reliant on video chipset and bus performance than anything- on the same motherboard, using the same cpu/BIOS settings etc, I doubled my framerate in 3dbench simply by going from an ISA ET4000 to a VLB S3 805.
What would be interesting to see, as part of your cpu scaling tests, is to throw in a gaming benchmark, like Quake timedemos or some other FPU intensive game.
However for what you are trying to achieve its probably not relevant- most 2.5D games like Doom, build engine etc were not FPU intensive at all. I remember Duke Nukem 3d ran faster on the 6x86 while Quake was slower.
If you are trying to scale your machine down to 486/386 level I don't think there are many games from that era that will require fast FPU performance. So the 6x86 might be perfect for that.
Reply 27 of 50, by Mau1wurf1977
Yea as soon as you need grunt > Slot 1 Pentium 3 all the way 🤣
Socket 7 is great for "slowdown" projects. Gives you a 386DX with L1 and L2 off and a 486DX2 with L1 off and L2 on.
However might as well get a 486 as this gives you even more options with the Turbo button. But I went with Socket 7 as the board is ATX and the boards happen to be on ebay when I was looking...
My YouTube channel
Reply 28 of 50, by HunterZ
Duke Nukem 3D ran quite well on my 486DX4-120, even in video modes between 320x200 and 640x480 (got a bit slow/choppy at the 640x480 end though). Quake of course clocked under 10 FPS. Daggerfall used a floating-point engine but used sprites for characters and monsters, so it was more playable but still noticeably sluggish.
Reply 29 of 50, by ratfink
Yeah, it was ctu I was thinking of, a windows application.
Reply 30 of 50, by 5u3
K6Clk has a Windows and a DOS utility.
The latter works standalone (without the help of a driver), but doesn't cooperate with protected mode memory managers.(Another reason to use UMBPCI 😉)
Reply 31 of 50, by Mau1wurf1977
Hehe the other day I tried Duke 3D on my Phenom II desktop. I made this DOS Usb Boot disk and it works great.
VESA 2 not an issue with todays video cards. I set it to 1024 x 768 and yea it looked amazing and it was super smooth. I couldn't measure the frame rate but easily 60 frames (or more) for sure...
Had no sound though 🙁
Reply 32 of 50, by retro games 100
My AMD K6-2 300 and 350 chips have arrived. Also, I found a K6-2 500 in my attic. The only chip I don't have is a 450. Nevermind, it doesn't matter too much. I ran Quake (1.06 shareware in DOS 6.22), with exactly the same "fast settings" BIOS values, and in full screen.
Reply 33 of 50, by retro games 100
K6-2: the revenge. 😉 After testing the K6-2 300 chip, I decided to see how far it could go. I ended up with it running @ ~440 MHz! (See speedsys below.) This was a multi of 3.5x (from 3), and an FSB of 125 (from 100). I needed to bump the voltage to 2.3v (from 2.2). The BIOS settings were maxed out. The external clock reading is wrong on the Speedsys image. It seems to have difficulty identifying OC'd FSB values.
However, I tried running Quake and it failed. I bumped the voltage up to 2.5v, but it still failed. However, Quake worked fine with the FSB reduced to 120. I got 67.7 FPS, which is half a point less than the OC'd P233 chip, in the table from my previous post.
Reply 34 of 50, by retro games 100
The K6-2 300 chip is stable at 420 MHz. Multi = 3.5, FSB = 120, Voltage = 2.3 in DOS and 2.4 in Windows. Here's the Windows 98 screenshot. I ran all of the SuperPi tests up to and including 1M. There may be a bug in this app. When you resize the screen, the values get altered. The real score for the 1M test was 7 minutes and something. The Sandra images show the 420 clock speed (to the right), and also the CPU and mulitmedia tests.
Reply 35 of 50, by retro games 100
Just for a bit of fun, I managed to get "the chomper" (a K6-2 300 MHz) up to 460 MHz! I needed to loosen up the BIOS settings, so that they were not "aggressive", and consequently the system's potency was reduced. Also, the CPU's voltage was set to 2.5. For the general timings, the multi was set to 4 (from 3), and the FSB was set to 115 (from 100).
Edit: I found some info about overclocking the K6-2 CPU here.
Reply 36 of 50, by bestemor
Sorry for this slight necro.... but anyone know how to clear the %&¤# cmos on this board ??? (ver 4.1)
Me stumped.... 😵
(bios password has accidentally? turned itself on it seems)
No mention of any jumper or even a blasted 'short circuit' in the manual...
(never understood the genius in using that last thing though.. I notice Asus has it on their version of this board)
Reply 38 of 50, by bestemor
Nah, sounds to 'easy'.... 😜
BUT, waddayouknow, that actually seemed to work!!
Beyond me though that the manual doesn't even mention how to do it...
Why does other/newer boards even have a jumper then ?
Ah, nevermind my tech ignorance...
Thanks a lot for quick tip !!! 😁
Reply 39 of 50, by Tetrium
These days, removing the battery is all I do. I fried a board by accidentally leaving the jumper to CLEAR_CMOS and applying power 🙁
Btw, RG100 where the heck are you hiding mate!
