Quake III Arena Benchmark Thread
Reply 40 of 203, by appiah4
leileilol wrote:
None of those 32-bit color or 32-bit textures will matter on V3 as they're clamped to 16-bit automatically due to what the GL ICD reports back to Q3.
"22-bit" is just a 2x2 box filter smudging your dither patterns. The framebuffer is the same
I can say for sure that the resulting image on the screen is not and the 32 bit option makes it a million times better.
Reply 41 of 203, by zerker
So I got my second video card installed and benchmarked it too. Results follow:
1346 frames, 27.7 seconds: 48.6 fps
Intel Pentium II-350
Intel SE440BX-2 Motherboard
Windows 98SE
192 MB RAM
ABIT Siluro GeForce 2 MX-400 (64 MB VRAM)
EDIT: Re-tested on Windows XP. Exact same specs otherwise:
1346 frames, 29.8 seconds: 45.2 fps
Reply 42 of 203, by slivercr
One of my new P3-S 1400 arrived today, so I figured I'd test it out and post my results. I was also in the mood to play with a Radeon 9100—a lower clocked 8500 that came out later—so I'm curious under which year you'll put the entry;
144.8 FPS, slivercr, Radeon 9100 @ 250/500 MHz (5.8 Catalyst), Pentium III-S 1400 @ 1400 MHz, intel OR840 (i840), 2 GB RDRAM PC800-45, XP-SP3
When the second Tualatin arrives I'll submit the dual CPU results, as well as those of a GF3 Ti 500 and a GF4 Ti 4600 😉
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 43 of 203, by appiah4
I just realized I may have benched with vsync o .. I need to check that in the 3dfx panel and rebench if necessary this weekend.
Reply 45 of 203, by slivercr
dexvx wrote:
How well does SMP work with this version of Quake 3?
Its buggy, to say the least. Hangs are common if you edit the cfg file with r_smp 1: most of the time you will be greeted by a blank screen when launching the game. Using the method above in this thread, editing the shortcut, has yet to fail me. It consistently launches the game for me.
Performance wise, you'll get a nice boost. In my system, with a couple of CuMine 1000 EB and a GeForce3 Ti 500 [GeForce4 Ti 4600] you are looking at 92.5 [93.3] fps without SMP, versus 115.2 [120.6] with SMP enabled.
Reply 46 of 203, by zerker
So my Pentium III-450 just arrived, and I swapped out the Pentium II and re-benchmarked it on both my cards (and OSes). I also reformatted my results up to now to match the format on the first page.
Here are the 3DFX results on both processors:
35.5 FPS, zerker, 3Dfx Voodoo III 2000 (4.12.01.0666) @ 143.2 MHz, Pentium II 350 @ 349.19 MHz, Intel SE440BX-2 (82440BX), 192MB SDRAM PC100 CL3-2-2, 98SE
38.9 FPS, zerker, 3Dfx Voodoo III 2000 (4.12.01.0666) @ 143.2 MHz, Pentium III 450 @ 448.96 MHz, Intel SE440BX-2 (82440BX), 192MB SDRAM PC100 CL3-2-2, 98SE
Next for the GeForce 2 MX. Didn't retest Win98 + GeForce on the Pentium III because I don't actually want to keep Windows 98 drivers enabled for this card. Last time I reverted to a backup after testing, which isn't my preference.
48.6 FPS, zerker, ABIT Siluro GeForce 2 MX-400 (81.98) @ 100/182.55 MHz, Pentium II 350 @ 349.19 MHz, Intel SE440BX-2 (82440BX), 192MB SDRAM PC100 CL3-2-2, 98SE
45.2 FPS, zerker, ABIT Siluro GeForce 2 MX-400 (93.71) @ 100/182.55, Pentium II 350 @ 349.19 MHz, Intel SE440BX-2 (82440BX), 192MB SDRAM PC100 CL3-2-2, XP-SP2
51.0 FPS, zerker, ABIT Siluro GeForce 2 MX-400 (93.71) @ 100/182.55 MHz, Pentium III 450 @ 448.96 MHz, Intel SE440BX-2 (82440BX), 192MB SDRAM PC100 CL3-2-2, XP-SP2
Incidentally, can anyone recommend a Windows-XP tool for grabbing the clock speed of a Video card? The Windows 98 tool I already had just bluescreens on Windows XP, and CPU-Z could supposedly grab that information, but is just blank for me right now (hence the TBCs above).
Reply 49 of 203, by silikone
Comparing Quake 3 benchmarks to Quake 2, is the difference in GPU capped performance mainly caused by the significant increase in polygons, or are all the "special" blending effects to blame?
Is 16-bit texturing inherent in the Voodoo 3? Are there no texture formats that offer higher quality on it?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 50 of 203, by dexvx
Polygons, increase texture size, and lighting.
Also, OP needs to update this thread
Reply 51 of 203, by silikone
What lighting? The lightmap density remains the same, but the dynamic lighting has regressed to blobs that forget to take the third dimension into account, as if they thought they were in the Doom engine. In addition, addition is not what they use. They instead blend with the lightmaps multiplicatively.
I understand that this was done to abolish texture uploads, which Id was a big opponent of, but still, the dlights might as well not be there, as they fail to do their one job: illuminate the darkness.
Reply 52 of 203, by leileilol
Q3's big non-graphical speed bottleneck is actually the QVM system. The slowness of QVMs meant excising a lot of things and putting hard limits on dynamic polygons and marks because it can't handle that much. This is mainly why Q3 didn't have a particle system.
You should see faster results when using DLLs instead, though getting those going would require MSVC6'ing your own from the Q3 SDK source or the original 1.32c gpl source release.
The dlights are a more expensive modulation blend (which cannot light up dark areas)
(some "pro" players also alleged the sound system in Q3's also slow, though i don't feel that's true first-hand)
Reply 53 of 203, by silikone
More expensive? Than additive blending? Then what is the benefit?
Did they not update the sound system at some point? I recall that the rockets did not have the doppler effect in early versions (probably delegating this to the then available A3D support).
Reply 55 of 203, by leileilol
Addiitve would wash out the texture detail. If you want an id tech3 example of additive dynamic lighting, play Alice.
Starting from 1.25 the soundsystem junked A3D support out as well as regress the channel handling (causing annoying overlapped sounds). This was deliberately done to avoid the "hitch" when going in and out of menus
Reply 56 of 203, by silikone
I presume this is a limitation of multitexturing. If they were done in two passes, could the dynamic lights be added so that the albedo would not be affected?
Actually, forget I asked. A veteran shouldn't have to lecture someone for free.
Reply 57 of 203, by leileilol
Unfortunately Q3's shader system is very unfriendly to any idea of combining textures with the lightmap. Jedi Academy did it but its method isn't compatible with other ideas for shaders like detail texturing...
FWIW the Q3tests had the old update-the-lightmap method instead (and this was incompatible with texture compression!!)
Reply 58 of 203, by falloutboy
Makes a big difference on my Super Socket 7 system. Have not testet with others.
44.8 fps with sound ; no a3d sound
62.9 fps without sound
Quake3 1.32 with custom settings (quite low)
demo four
K6-III+ 550MHz
Tyan S1590
GeForce3-Ti200 Det. 14.10
Vortex 2
Win98SE
In Quake 2 it's only 5% difference on that system.
Reply 59 of 203, by Fusion
Running the Q3A Demo v1.11, demo001 I get 50.3fps at 1024x768 high settings. With my Voodoo 3 3000 @ 195/195.
With a few tweaks I can hit near 60fps with little image quality loss. 😎
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 200/186 - SB Live! 5.1 - Windows ME
