Reply 100 of 472, by GL1zdA
- Oldbie
keropi wrote on 2025-02-04, 09:46:Not dissing ESS but it has worst sound performance, no external opl3 support, no spdif , no 16bit audio for DOS some can be fixe […]
GL1zdA wrote on 2025-02-04, 09:20:Which CS4237 features are you missing in the ES1869?[...]
some can be fixed externally by adding stuff but the quality performance and internal design cannot be fixed
but you gain more sbpro compatibilty with ESS so there's that 😀
By sound performance you mean SNR and similar parameters? Or are there other flaws?
As for external FM, what is the problem with the ESS? I remember you've used a creative way to connect the OPL3 to the CS4237 (via the CS9236 port?), I assume it's impossible on the ESS?
I've always believed "Windows Sound Support" in ESS datasheets meant DOS WSS support, but now I see it probably mean compatibility with the Windows mixer etc. What a bummer, never tested it and somehow missed there's no 16-bit DOS audio in DOS on the ESS.
