Repairing a 486 DX
Reply 60 of 63, by IBMPCATFAN1984
appiah4 wrote on 2024-10-14, 06:03:
Not sure if this was mentioned earlier but that board has a TH1287 realtime clock chip which I would assume is a Dallas DS1287 clone. Regardless, it is probably flat, and I've seen many 486 boards not POST at all without a working one. So replacing that might be a first order of business here.
Sounds like a good idea, some companies still make replacements for the Ds-1287!
It would be a great opportunity to find someone who knows how to solder, to teach me how to solder (i learn better by doing and learning person to person)
Buut… i have to wait for my father to come home from a work trip before i do anything.
Reply 61 of 63, by IBMPCATFAN1984
Reply 62 of 63, by myne
Search for YouTube vids on them.
The plastic casing can be removed easiest with heat. It crumbles.
https://m.youtube.com/watch?v=ecTZtZhE9bI&pp= … GFzIFJ0YyBoZWF0
From there, it is relatively straightforward.
Soldering isn't strictly necessary. Twisting wires isn't ideal, but it works at least to test.
It's in a hell of an awkward spot though.
For removal, your best bet is low melt solder and connecting all the pins on the back with a fairly thick wire bent into a u shape.
https://m.youtube.com/watch?v=kYpyH89v14c&pp= … vciBzb2xkZXI%3D
I built:
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 63 of 63, by IBMPCATFAN1984
myne wrote on 2024-10-15, 05:38:
Search for YouTube vids on them. […]
I personally do not own a soldering gun, but, i will attempt to aquire one!
The chip is soldered onto the board though, i tugged a couple of times.
I found a replacement chip, but it is out of stock right now https://www.wiltronics.com.au/product/3816/da … eal-time-clock/
