First post, by Johnisnotcool
Whenever I start dosbox I get a "failed to creat a rendering output"
Haha My problem was not in finding a way to fix it(many other people seem to have the same problem) but in understanding what they are talking about when they say what to do.
most of them said something about "SDL_VIDEODRIVER=windib" But I didn't really understand haha
Anybody who could break it dont alittle bit for me and tell me were I'm supposed to put that would be helping me a ton!
Thanks!
Reply 1 of 9, by DosFreak
Well before doing anything...
1. Update video drivers.
2. Try different output modes in DosBox conf
Surface
Overlay
opengl
openglnb
ddraw
direct3d
If that doesn't work then:
Hit "Windows Key" + "Pause Key"
Go to Advanced Tab
Choose Environment Variables Tab
Create a variable called "SDL_VIDEODRIVER"
Use value of Windib
or create a batch file called dosbox.bat.
In dosbox.bat
SET SDL_VIDEODRIVER=windib
dosbox.exe
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 9, by Guest
I tried all of that. Nothing has worked so far.
I did this
"Hit "Windows Key" + "Pause Key"
Go to Advanced Tab
Use value of Windib "
and Dosbox doesn't even start anymore... do I need to restart before I try it?
Reply 3 of 9, by DosFreak
Okay....
Remove what you just added in Environment Variables.
Click On "DosBox CVS Builds" in my signature.
Scroll down to ykwon's build
Download his build of dosbox and see if that fixes your problem.
Reply 5 of 9, by DosFreak
Wow. What kind of video card do you have?
Reply 6 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Changing the color depth to 16bpp (display properties) works around that. The video card on my older machine showing this error is the Riva 128. Normal Dosbox CVS does not bring up that error, it's possibly some 3D stuff in ykhwong's build.
Reply 9 of 9, by DosFreak
Thanks for replying back. It's good to get this info since it seems alot of people use DosBox with dinosaur age video cards and we get strange behavior from that.
