Graphics card PCIe working on Win95
Reply 20 of 30, by fosterwj03
Someone mentioned on the Radeon 9xxx / Win95 threads that later Catelyst driver packages for Win9x only included WDM drivers. Those can't work with Windows 95 at all.
I suspect that packages after Catalyst 4.3 (which predates PCIE support by about half a year) don't include VXD drivers compatible with Windows 95.
Edit: corrected the Catalyst version number.
Reply 21 of 30, by Gelip
I tested different Catalyst drivers from 3.1 to 6.2 but none works in Win95 🙁
Drivers from 3.1 to 4.2 not support ATI X300 and I installed manually choosing the first on the list, i.e. ALL-IN-WONDER 9000. Only 6.2 supports this card but it doesn't work anyway.
The driver installer displays interesting information:
3.6 & 3.7 - in English:
The attachment 36_7-91_no_DX9_EN.png is no longer available
3.8 - same but localized:
The attachment 38_7-94_no_DX9_PL.png is no longer available
3.9 - 4.2 - localized (Setup was unable to find components that can be installed on your current hardware or software configuration, Please make sure you have the required hardware or software.)
The attachment 39_7-95_PL.png is no longer available
I also tried the Win98SE, the driver 6.2 works but as soon as I start something that requires a 3D screen freezes and the system hangs - it's the same as in WinXP
In Win98SE I also tried NVIDIA 6200 card - different drivers but on each system hangs, a black screen is made, etc. 🙁
I also tried the PCI S3 Virge 4 MB VRAM cards, and it works OK, max. resolution is 1280x1024 16-bit but normally I don't want to use the PCI graphics card because I have Sound Blaster Live!
Reply 22 of 30, by agent_x007
If I had to guess, it's DirectX version limit that's screwing you over. Win95 "tops out" at 8.0a : https://falconfly.vogonswiki.com/directx.html
When driver expects files from DX9, and they are not there... expect issues.
Reply 23 of 30, by fosterwj03
Yeah, that's in line with my experience. ATI's PCIE drivers just have too many dependencies on software features that Win95 doesn't support. When ATI described their drivers for "Win9x", they really meant Windows 98 SE and Me.
I really wish an affordable AGP-to-PCIE adapter existed.
For Windows 98, I think the drivers need DirectX 9 and Internet Explorer 6.0 installed first. That's the order I use when I set up a Win98 install on modern hardware.
Reply 24 of 30, by Gelip
I moved to another PC with motherboard AIMB-786, Intel CPU 8 Gen Coffee Lake, 16 GB RAM
Now I'm trying to run the NVIDIA 6200 PCIe Card in Win95. To run the Win95 system you need to additionally CREGFIX.COM, otherwise there is a VCACHE error.
After install GPU driver (66.94 or modded 82.69) Win95 not boot and reboot. I tried:
PATCHNVC NVCORE.BAK NVCORE.VXD
but it doesn't help. I have a question - do I have to do it to use patch also patch BIOS, OPTIONROM and FIXINTR VXD ???
Maybe I need use other patch: ShutdownPatcher - how use it?
The attachment sp.png is no longer available
Reply 25 of 30, by DarthSun
Gelip wrote on 2025-09-14, 14:56:
I moved to another PC with motherboard AIMB-786, Intel CPU 8 Gen Coffee Lake, 16 GB RAM […]
It probably doesn't get an IRQ. I have a similar situation on my X299.
FIXEOI maybe. I wouldn't recommend an optionrom...
It gets the VGA IRQ on my Zen2, B450 board, and 3 other machines too.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 26 of 30, by Gelip
DarthSun wrote on 2025-09-14, 16:37:
FIXEOI maybe.
I tried all drivers FIX*.* but always error that device file is damaged.
Reply 27 of 30, by Gelip
I decided to test the ATI X300 card in another PC under WinXP 64-bit: Asus P8H61-M LE R2 (SandyBridge)
WinXP 64-bit has own drivers, the desktop works well in the native monitor resolution 1360x768. I installed NFS3 + Modern Patch 1.6.1 and started playing in the same resolution as the desktop, i.e. 1360x768. I played about 15 minutes and it was OK. Unfortunately, at some point the game stopped - the screen froze and went out - it got black but in a moment the VPU Recover window appeared, the operating system did not hang, only the game stopped answering - I could press Ctrl+Alt+Del to start the Task Manager and close the game:
The attachment H61_crash_but_OS_not_hang.png is no longer available
I immediately checked the GPU temperature in the GPU-Z, but it's 40 degrees so OK:
The attachment H61_temp_40.png is no longer available
There is something wrong with this card - maybe an electronic element on PCB is overheating.
I will refund the parcel tomorrow. I've had enough 🙁 👎 👎 👎
Reply 28 of 30, by vvbee
There was someone on eBay selling a for-parts X300 saying it has the same issue, drivers work on the desktop but freezes when you start 3D. Is this some common failure mode with these cards? Or are they finicky about what they'll run on?
Mine is a HP part from ASUS. With the normal Catalyst it'll freeze in 3D typically within seconds, even in the Catalyst Control Center's 3D preview. Now I tried some drivers from HP and they work better, can complete about 1.5 rounds of the chopper test in 3DMark 2000 before freezing. This is suspicious behavior.
Nothing on the card is obviously overheating on thermal camera and it has a fan on the heatsink. A while back I measured one voltage regulator and it was working as expected from what I remember. All wet capacitors were replaced, some of them were off.
Reply 29 of 30, by Gelip
@vvbee
If there are problems in every Win95, Win98SE, WinXP system, it means that there is something wrong with the X300 card - probably a design defect.
P.S. I tried the PCIe NVIDIA 6200 card in Win95 but there were also problems.
I changed to WinNT 4.0 SP6 and now can use the PCIe NVIDIA 6200 graphics card normally (drivers 71.84). The OS only supports DirectX 3, but OpenGL games run without any problems, e.g. Serious Sam:
The attachment ss1.png is no longer available
The attachment ss2.png is no longer available
The attachment ss3.png is no longer available
Reply 30 of 30, by vvbee
It could be a bad card, but so far I've seen one game, Johnny Herbert's Grand Prix Championship 1998, that doesn't freeze. I've left it running for half an hour and it was still fine. To me this says the hardware must be working. Of course it could be that this game just doesn't use whatever part of the chip that's not working properly, but it seems unlikely.
