Ctrl+F5 in dos program
First post, by Chook
Hi I'm using an old program that doesn't run on WinXP
I use dosbox to make it run 😀
But in some cases i need to use the key combination CTRL+F5
But the program doesn't seem to respond to it.
It's very important to me,
Plz advise.
Chen.
Reply 1 of 3, by eL_PuSHeR
I don't know if CTRL-F5 (default for DOSBox screen capture) can be unbound by using the keymapper (CTRL-F1). Just try it.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by Guest
It worked!!! Thanks alot..
🤣 you won't believe how many PNG files i've mistakley created while trying to figure this one out 😀
Reply 3 of 3, by jal
PNG files are small. Try for a change Ctrl-F6 (captures sound) without knowing what it does. I thus created a 2Gb WAV-file, filling up the remainder of my free disk space 😀.
JAL
