Any sense buying modern PSU for old hardware?
Reply 20 of 174, by AlexZ
They are so cheap you can get 400W, no need to look at 250-300W at all. If you don't find good ones, look at 350W. We are dealing with 25 years old worn out PSUs.
Locally I see Maxpower 400W for 9 EUR and FSP Blue Storm II 400W (3.3V+5V=152W, but 30A on 5V) for 12 EUR without postage, there is also an Eurocase 400W for 8 EUR. People are basically giving them away almost for free.
250W PSU was used for PII ATX boards.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 21 of 174, by CharlieFoxtrot
AlexZ wrote on 2026-04-23, 20:48:
Agree, you should find old 5V heavy PSUs cheap.
As I like to toy around with Socket A, I have many of these early 2000s 5V heavy PSUs, most are Enermax, but I have one odd GlobalWin (ToPower design) and BeQuiet too (again ToPower).
Although most of these have had secondary side caps that both look good and also measure in spec, I would by default recap these before putting them in any serious use. For example, that GlobalWin ToPower had leaked Teapo caps even though it was NOS. Enermax PSUs from this era also use Teapo heavily and I just recently recapped one with swollen and leaked Teapo caps, although few have been just fine. Teapo isn’t high quality, but there are even worse caps out there. And the quality can vary wildly with these cheap brands.
And even with quality caps these PSUs are a big unknown. They are 25 or so years old, you don’t know how many hours they have seen or how they have been stored along the years, all of which will affect the reliability of thes caps and thus PSUs.
So, if one can’t or doesn’t want to do these kinds of recaps, I would go with a motherboard that supports 12V VRM so you can use newer PSUs. For example, most nForce2 motherboards have that. On the otherhand, very few VIA chipset boards seem to have 12V CPU VRM, even with the later series such as KT600.
Reply 22 of 174, by shevalier
To be honest, I don’t know where you can even find a ‘proper’ PSU in good working order these days.
From my collection at home
- Enlight 250W - 25 years old
- FSP 400-pnr + Chieftec 350Watt - 20 years old
- Hipro HP-D5201aw - 15 years old.
The capacitors in the secondary circuits have all failed, and in the case of the Hipro 520W – the very first one, whilst it was still in active use with the Phenom 2 X6.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 23 of 174, by momaka
Caesum wrote on 2026-04-23, 09:00:
A 250W overall PSU should be sufficient for my specs as it's a cheap PC. It shouldn't be an Active PFC type.
Would that still apply for a Voodoo card if I wanted to buy one eventually? I assume Voodoo 1 wouldn't be too power hungry but newer Voodoos are probably way more demanding.
An old good quality 200-250 Watt PSU will be able to handle a pair of VooDoo IIs just fine... or a VooDoo 3 - 5 for that matter. They are not that power hungry. Well, the VooDoo 5's do get up there, IIRC. Still not as bad as a Radeon 9700 Pro / 9800 Pro, though - these are the worst for power draw on the 3.3V and 5V rail, as I mentioned previously.
The power is irrelevant when the PSU is shit.
An OEM quality 200-250 Watt PSU from a Dell or HP (provided it's not a proprietary pinout one) will run circles around any no-name "400" Watt garbage.
Maxpower is garbage. Bad caps galore inside and undersized components everywhere.
The FPS Blue Storm II is ATX v2.x, IIRC, and not suitable for 5V-heavy systems. There was a thread here not too long ago about another FSP PSU from the same platform. The idea was to try and convert it to a 5V-heavy design... and TLDR, it was simply not possible as I suspected and suggested to the O/P. I'll dig out the thread if you really care.
Eurocase, IIRC, is also cheap garbage - typically Deer/L&C/Allied (which can be worked into a decent PSU for an old system... if you spend the time to install/replace all of the parts inside that the manufacturer saved on.)
8 Euro?! No way, I wouldn't even give them 3 Euro for these. FWIW, my local flea market is flooded with such crap PSUs and I can almost always get one for 1 to 2 Euro . I just don't anymore, because my basement is flooded with these already. Gonna take pictures and fix some of the better ones just for shits and giggles... but they are still pretty bad PSUs.
No, Dell and HP used 240-260 Watt PSUs in just about everything from the Pentium 4 to 6th gen core i5 systems.
When all you got is a <100W TDP CPU in a system and onboard GPU, you don't need that much power.
For what it's worth, the nVidiar Riva TNT2 from O/P's first post is about on par with the power consumption as an IGP.
So really only the CPU power is the most relevant to the O/P's system.
Caesum wrote on 2026-04-23, 20:34:
I found a Seasonic PSU that's been renewed (whatever that means) and it seems it would have been perfect for my build at a first glance and it's not too pricy (80PLN == 19 EUR). What do you guys think? One thing I have noticed about is the AC Input. Most PSUs I checked have 200-240VAC 3A 50/60Hz but this one has 4.5A, but I guess this shouldn't really be an issue?
That's a good PSU. Probably the best find for your system.
Before buying it, just ask if you can take a look at it and have a peek through the vents on the case. Bad caps aren't always easy to spot this way, but they can be if you've done it enough. 😉
Though if I am not mistaken, old Seasonic PSUs that were branded as Seasonic's own actually used pretty decent (if not solely Japanese) caps.
Mike_ wrote on 2026-04-23, 09:23:
However, is the PSU so dumb that it will throttle fan based on power use rather than temperature? It doesn't say whether that graph is just a measured graph based on how a modern computer uses power.
The problem with the modern PSUs that use DC-DC converters for the 3.3V and 5V rails is that regardless of whether the fan depends on the temperature or the power use (or both), it's still probably only for the 12V rail output, since that's what's used on a modern PC. The DC-DC converters are typically not monitored for temperature. And here's the thing: even a rather power-hungry old 5V-heavy PC won't typically draw over 120-140 Watts of power. Because of this, a modern PSU won't heat up much on the overall due to it's high efficiency. However, the DC-DC regulators will already be running close to the maximum of their capacity while the PSU is barely idling the fan. So that's what @shevalier meant that new PSUs are not quite ideal for heavy 3.3V and 5V heavy loads. Though I would say that really only applies for the very 5V-heavy "hitters". In the case of the O/P's system, that's setup won't be as power-hungry on the 5V rail as some other socket A systems are. So IME, a modern PSU with DC-DC converters would also be possible to use in this case.
And in any case, if one had to choose between modern PSUs, I would still recommend a modern PSU with DC-DC converters over a modern PSU with a group-regulated design - the latter will almost definitely not run well (or at all) in spec with an old 5V-heavy(er) PC.
CharlieFoxtrot wrote on 2026-04-24, 05:20:
Nah, if the caps are quality Japanese ones, you can bet your undies the PSU will be fine. All one has to do is blow out the dust and make sure the fan is OK. My experience decomissioning old industrial / service equipment is that quality-built PSUs tend to just keep going and going. 30 years 24/7 in harsh dusty conditions is nothing for a PSU if it was built well and maintained (dusted) at least somewhat regularly (i.e. not allowed to completely cake up... though I have seen a number of such PSUs too, and they too were just fine.)
In fact, I'll take any old quality-made PSU over the modern stuff, especially anything withOUT APFC. IME, APFC circuits just don't last all that long in consumer-grade stuff. That's because most APFC designs tend to put a lot of stress on the primary electrolytic cap(s) and anything over 10-15 years (depending on the design and quality of the caps) should be checked (the primary caps, that is.)
Meanwhile, the oldschool non-APFC (or just PPFC) designs are near bullet-proof on that front - even the worst garbage caps will easily last 20+ years in these.
shevalier wrote on 2026-04-24, 10:39:
One word: Astec.
Shhh... don't tell anyone else, I'd like to keep more for myself. 😉
Granted these are not as easy to run into as other OEMs. But they are usually very nicely built. The only thing I don't like that I persistently see with Astec PSUs is they tend to have loud fans and/or fan controllers set to run the fan too hard.
That said, my GO-TO PSUs for testing 5V-heavy PCs are the Dell/HiPro/Chicony HP-P2507F3P and HP-P2507FWP - these are so over-built that even with a failed cap or two, they still stay in spec most of the time. It was something that JohnnyGuru tested a-way-while back in a "basement" PSU roundup. The old HiPro had a failed cap on the output and still managed to deliver full output power completely in spec. You just don't see this kind of over-building of PSUs anymore, where everything is running right on the limit and well-calculated to last just past the warranty.
Reply 24 of 174, by Grem Five
momaka wrote on 2026-04-25, 22:39:
A few years ago I got back from my parents an old system they used for over 10 years and I probably used it for a few years before I gave it to them that had a 300 watt Allied psu powering it. Its was an AMD Athlon 1200c / Voodoo3 3000 build I made back in the day and still powered up and ran fine when I got it back.
I changed the psu to a better unit after I got it back but the allied psu is still running in spec when I check it now.
I wouldnt recommend one today as after that build I went to seasonics but it has lasted longer than other better brands ones I have seen in friends builds. I must have gotten a golden allied psu somehow.
Reply 25 of 174, by lti
Allied was the "high-end" Deer alias brand. They still blew up before reaching their rated power, but they had full output filtering.
I somehow still have a working Hipro from 1998 with its original Su'scon caps. It's also overbuilt, but the protection circuit isn't very good.
Reply 26 of 174, by cyclone3d
For modern Seasonic, if you go up to 650W or higher, you get 25A on 5v on a bunch of different models.
SS-650KM (80+ Gold - 25A on 5v)
SS-600ES (older 80+ bronze - 24A on 5v)
SS-500ET (older 80+ bronze -24A on 5v)
SS-760XP (80+ platinum - 25A on 5v)
SS-750HT (older 80+ Silver - 30A on 5v)
SS-550HT (older 80+ - 30A on 5v)
SS-500HM (older 80+ - 30A on 5v)
SS-300FS (just older - 30A on 5v)
SS-520GM (80+ Bronze - 24A on 5v)
SS-620GM2 (80+ Bronze - 24A on 5v)
SS-620GB (80+ Bronze - 24A on 5v)
SS-660XP (80+ Platinum -25A on 5v)
SS -660XP2 (80+ Platinum -25A on 5v)
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 27 of 174, by AlexZ
Those Seasonics have only ~130W on 3.3V+5V
SS-650KM - 3.3V+5V = 125W max
SS-600ES - 3.3V+5V = 130W max
SS-500ET - 3.3V+5V = 130W max
SS-760XP - 3.3V+5V = 125W max
SS-620GB - 3.3V+5V = 130W max
Some PSUs sold locally:
Dell OptiPlex 235W 3.3V+5V = 88W max
Dell XK376 305W - 3.3V+5V = 150W max
Chieftec GPF-250P 3.3V+5V = 90W max
Chieftec GPA-400S8 3.3V+5V = 120W max
Seasonic SSP-350GT APFC 3.3V+5V = 80W max
Seasonic SS-400ET APFC 3.3V+5V = 130W max
HP FH-XD301MYF (300W) 3.3V+5V = 103W max
Eurocase ATX-350WA-12, 3.3V+5V = 100W max
This illustrates many 350-400W PSUs are too new and 250W ones have low max load on 3.3V+5V. Period correct Eurocase 350X has 3.3V+5V = 185W max and had both -5V and -12V. Sometimes newer PSUs like Chill CP-510A also do have -5V and -12V, including strong 3.3V+5V rails, 330W in this case. Sometimes they sell for 1 EUR on auction, but one has to keep an eye on them.
Historically, I remember 300W PSUs being used up to about ~1Ghz CPUs, 350W up to ~2Ghz (Athlon XP, Athlon 64), 400W for early dual cores. From the Athlon XP PCs I bought many had 350W.
I only buy used PSUs in person, never have them shipped to me. I once refused to buy a Corsair 600W that was too dirty. It had so much dirt I have never seen in a PSU. If you would like to have them shipped, ask the seller to disassemble them and take close pictures.
Reply 28 of 174, by The Serpent Rider
We'll need a separate +5v/+3.3v converter for old systems eventually.
Reply 29 of 174, by tehsiggi
The Serpent Rider wrote on 2026-04-26, 08:29:
I'd have to search in one project directory.. started something like that at some point.. taking the ATX24 pin + 2x6pin PCIe and generating 5V 15A and 3.3V 20A and feeding it out to ATX 20 pin again. Don't think I ever bothered to go further with it, as I had fitting power supplies. Idea was to have it plug in between.
I wonder if there's "real" demand for it. If so I could make it into a JLCPCB project or something, where they could also assemble it.
I just don't think it's going to be cost-effective as a small project.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 30 of 174, by shevalier
tehsiggi wrote on 2026-04-26, 08:37:
I'd have to search in one project directory.. started something like that at some point.. taking the ATX24 pin + 2x6pin PCIe and […]
That makes no sense.
ATX power supplies with DC/DC converters do not have a power summing circuit to monitor the total load on those converters.
They only have short-circuit protection on each channel and overheating protection for the PWM controller itself.
In other words, they can easily deliver 25 +25 A of current simultaneously on both the 3.3 V and 5 V rails.
If there were a demand for an “old-school capable PSU,” manufacturers would simply add heatsinks to the DC/DC MOSFETs to ensure continuous operation at such power levels.
Or a PSU without a fan-stop function, with the converters properly positioned beneath the fan, like this Corsair CX-M Series 450 W
https://www.techpowerup.com/review/corsair-cx … m-series-450-w/
But I won't recommend it, because I have no idea how it will actually perform.
Reply 31 of 174, by tehsiggi
shevalier wrote on 2026-04-26, 08:53:
That makes no sense. ATX power supplies with DC/DC converters do not have a power summing circuit to monitor the total load on t […]
In other words, they can easily deliver 25 A of current simultaneously on both the 3.3 V and 5 V rails.
The converter will only use the 12V rail of the ATX supply + the 2 x 6pin PCIe to generate the 3.3V + 5V that are going out to the mainboard. I nowhere mentioned to merge the 3.3V and 5V of the PSU with it. They can be used for peripherals like HDD, SSD, optical drives etc. via the SATA/4Pin plugs.
To me it sounded much better than hoping the modern PSU wouldn't switch off, even having to modify / influence it's cooling in any way. I basically didn't want to care anymore what I use to power my hardware. I wanted it to be predictable and reliable.
But before i finished, I found and recapped an old Codegen 500W with enough oohmpf on the 3.3V + 5V rails combined. And by demand I don't mean a commercial product, but rather by the niche that is retro computing enthusiasts
Reply 32 of 174, by shevalier
Used units with an APFC may have a different issue.
The power supply turns on, all voltages are present, but the system does not boot.
This definitely applies to CWT PSH -1/2 as portrayed by Chieftec and Corsair.
Due to being over 10 years old, the adhesive under the megaohm SMD resistors begins to conduct 🙁
The APFC controller detects that the voltage is already high and does not allow it to rise to 380 volts.
Therefore, the Power Good signal is not sent, and the motherboard does not boot.
The problem with these resistors is that they are from a special high-voltage series (up to 500 volts).
If you use a standard thick-film resistor, the 200-volt voltage will cause them to degrade within a year or two.
You need to install 3 of them (3*650kOhm) instead of 2 *1 MOhm during repair.
That is precisely why using a power supply that is more than 10 years old poses a real lottery.
Reply 33 of 174, by shevalier
tehsiggi wrote on 2026-04-26, 08:54:
The converter will only use the 12V rail of the ATX supply + the 2 x 6pin PCIe to generate the 3.3V + 5V that are going out to t […]
https://www.aliexpress.com/item/1005003750287168.html
https://www.aliexpress.com/item/32630896191.html
PICO PSUs have been around for a long time, but their specifications are unknown.
I haven't seen any branded ones—just some from a Chinese online store.
Reply 34 of 174, by tehsiggi
shevalier wrote on 2026-04-26, 09:12:
https://www.aliexpress.com/item/1005003750287168.html https://www.aliexpress.com/item/32630896191.html PICO PSUs have been aroun […]
Here's the spec for the first one..
https://pico-box.com/docs/x7-atx-500-user-manual/
Poor current delivery on 5V and 3.3V (8A each) - as to be expected, the era of 5V and 3.3V are over.
my goal was to retain the normal ATX supply and just "supplement" it to support older hardware.
Reply 35 of 174, by AlexZ
Strong power delivery on 3.3V+5V is rare. Like 1 in 20 sold PSUs has it. I have not seen it in old Seasonic or Chieftec sold locally as people used to buy cheap PSUs and those are now resold. I think you will have to eventually learn to repair period correct PSUs.
I found a few suitable ones locally, but all cheap brands:
Period correct:
Eurocase 350X - 3.3V+5V = 185W max (has -5V, -12V)
Maxpower PX-400 - 3.3V+5V = 255W max (yes I know Maxpower are bad, has -5V, -12V)
Maxpower PZ-500 - 3.3V+5V = 275W (has -5V, -12V)
Modern:
Be Quiet BQT P6-Pro (430W) - 3.3V+5V = 170W (modular, has -5V, -12V)
Corsair CMPSU-850TX (850W) - 3.3V+5V = 180W (no -5V)
So anyone looking for a Seasonic or Chieftec will be disappointed. They simply don't sell.
Reply 36 of 174, by PcBytes
Chieftecs are fairly common in Hungary. I got mine (350W, Delta OEM) off Vinted so might wanna check there.
Reply 37 of 174, by shevalier
AlexZ wrote on 2026-04-26, 09:47:
Modern:
In most countries around the world, children born in the year this PSU was released are already of legal drinking age 😀
Sorry, I couldn’t hold myself.
In our market, for example, there’s the "fresh" FSP-500PNR Pro model (rebrending of "PNR-I" series, not of old-school PNR/PAF/etc.)
In other words, it’s currently being manufactured and sold. However, it’s not a widely available option; it’s hardly sold outside our region at the moment.
Reply 38 of 174, by shevalier
As for “local” brands owned by large retailers.
In Ukraine, this is VINGA, part of the ‘Brain’ chain of shops.
Vinga VPS-750GV2
Vinga 450W (PSU-450-12)
image;s=1000x700
image;s=1000x700
So, try recommending a local brand's PSU after that...
Reply 39 of 174, by CharlieFoxtrot
This is so wrong in many ways. No one should trust very old components that have a manufacturer shelf life even when sitting unused, but especially when we are talking about electronics with unknown hours and history. Besides, I have opened quite a bunch of PSUs from this era and I don’t remember a single one having those ”quality japanese ones”.
And you know exactly how these used CPUs are maintained during thelast 25 years or so unless you have owned that PSU from the beginning?
You really can’t directly compare industrial equipment to your cheap consumer grade PSUs in any way. I bet in many industrial applications linear PSUs are still a thing because reliability is prioritized instead of the size and efficiency. And PSUs that are used in equipment that are exposed to elements and/or dirt, you can bet that these conditions are take into the account in the overall design. None of this is true with your run of the mill desktop PSUs which are not even up to the quality of server grade components.
Again, and like I said myself, how much the PSU is used, how it is stored and maintained affects how long the components of the PSU will last. You have no clue how many hours those caps have seen, what kind of temperatures they have been exposed to (this also varies by the design, for example caps right next to mosfets can have significantly shorter lifespan) or how the unit has been stored after it has been decomessioned.
Of course these old power supplies can stil be in fully functioning condition and have several years ahead of them, I’ve personally checked and recapped several such units and I’ve not claimed otherwise. But saying thta you can trust such vintage power supplies if it has brand X capacitors is absolutely wrong. Blindly trusting such mains voltage equipment can lead to a disaster at some point. And the worst case scenario is not the vintage system the PSU should provide smooth DC power, but your house.
