Operating Systems for i586
Reply 20 of 27, by mscdex
st31276a wrote on 2026-05-05, 14:43:
The sse2 emulation might still be needed for things like firefox that is somehow difficult to compile without it.
For 586-class CPUs, modern versions of Firefox would run slow no matter what. You're better off with elinks/links2, dillo, or netsurf, all of which can be used without an X server and will be your best bet at doing any kind of fast/modern web browsing on a 586-based system.
Reply 21 of 27, by Jo22
mscdex wrote on 2026-05-05, 17:50:
Dillo got an update not long ago! 😃
I wonder if it's still possible to compile a new DOS version.
https://dillo-browser.github.io/release/3.2.0/
PS: PC GEOS got updated, too.
The latest version has a more recent web browser, even. 😎
Re: Retro OSes for retro computers
Reply 23 of 27, by Jo22
mscdex wrote on 2026-05-07, 15:49:
Jo22 wrote on 2026-05-05, 17:59:
There was a 3.3.0 released on April 26.
Hey, thank's a lot for the info! 😎👍
The more modern (maintained) web browsers there are out there, the better for the web.
Diversity is what keeps the web slowing down from getting too centralized too fast, I think.
The more rendering engines there are in circulation, the healthier the outcome.
Reply 24 of 27, by DEAT
the3dfxdude wrote on 2026-05-05, 13:17:
There are some guys working on a fork for the drivers, to bring some of them back.
Not really - all they're doing is fixing compiler warnings and ripping out XAA acceleration while not doing any conversion of the XAA code to EXA, or even testing the hardware. Good luck with using xf86-video-mach64 (covering everything from mach32 to Rage Pro/XL) and xf86-video-sis drivers as they will unconditionally segfault, my brief tests with xf86-video-mga and xf86-video-r128 were also not promising. A lot of the drivers are effectively framebuffers now, ironically one of the few drivers that has working EXA acceleration is xf86-video-trident, and it appears to be limited to Trident Blade3D 9880 cards.
So it's entirely possible to start fixing all the issues and bring back good support.
On the plus side - historical source code is easy to obtain and with the availability of datasheets and PCem/86Box (also MAME?) code, it shouldn't theoretically take too much effort for anyone who is willing and has the hardware. Going KMS is also a possibility, the Matrox G200 code in the kernel appears simple enough at a cursory glance that it shouldn't be too hard to port the code to other chipsets.
But if you wanted to do this for recent stuff, it's alot of work to base it on any mainstream distro, so you might as well start from scratch and make something work well on i586, or a known good variant, but which?
I already answered that in this thread - install Gentoo.
win16.page | Twitch
Reply 25 of 27, by leency
KolibriOS is insanely cool, it runs great, only needs a floppy drive, has impeccable aesthetics and is seemingly impossible to install to disk without Windows. It also doesn't support any networking adapters I own. My spouse uses it with their Libretto FF1100V and enjoys the experience considerably.
KolibriOS dev here. Thanks for a sweet words!
You can install KolibriOS on a drive in a very simple way: using "Hybrid UEFI/BIOS image BETA" from here https://kolibrios.org/en/download . Just write an image to your HDD (I use CF-card) and boot on your i586 PC.
About network. It must work, tested by myself a lot of times. The list of supported LAN-cards is wide https://wiki.kolibrios.org/wiki/Hardware_Support#Network
Note: much newer bulds here https://git.kolibrios.org/KolibriOS/kolibrios/actions
Regards,
Leency
Reply 26 of 27, by shitbird
PC@LIVE wrote on 2026-05-01, 13:34:
Well I'm interested, if you can get a working installation, I would like to know what type of PC you use (configuration), and especially if you can tell me which version to use, if it was possible where I can find it, I don't know if the one I tried was a beta version, so not definitive, I remember that I was suggested to install it, to check if there was any working problems, and in fact there were at least some.
A bit of an update on this - I have successfully installed the current version on a K6-3+/MVP3 system. It runs quite well, however, the method for installing drivers is complex and consuming of more time than I was willing to commit. It didn't really need much after install, really, and the install itself was easy, but the computer is used for edutainment and the sound drivers were the issue. Just burn the current version to a CD and give it a go, is what I would recommend. Very straightforward so long as you have a bootable CD drive. In some weeks I'll probably give a try on an Athlon64 and report back on that, as well.
Reply 27 of 27, by shitbird
leency wrote on 2026-05-15, 08:33:
You're quite welcome, your work is very impressive and deserving of them.
Ah, yes, I suppose I should have thought of this. Thank you, sometimes someone simply needs to point out the obvious.
I don't doubt networking works! I would love to use it, as well, but my issue is that I don't own any cards with a chipset listed in the table you've linked. It's fine, I'll acquire one eventually.
Regards,
Leency
Neat, I will check them out. Thank you for taking the time to give me some help!
