First post, by Skazzaks
Hi everyone,
I’m working on a Windows 95 build with a Soyo SY-5VD / 5VD5 Socket 7 motherboard using the Intel 430VX chipset.
System:
Soyo SY-5VD / 5VD5
Award BIOS VD-1BA1, 11/19/98
Pentium MMX 233
Windows 95 OSR2.x
Goal: 64MB total RAM, ideally 2 × 32MB SDRAM
The issue:
I first tried 2 × 64MB Compaq PC100 SDRAM, P/N 323012-001. The board detected them as 16MB each, which I assume is a chip-density issue.
Then I tried two supposedly 32MB PC100 SDRAM DIMMs, both 16-chip modules with 8 chips per side. These also only detect as 16MB each, so the system still shows 32MB total.
The chip markings I can read:
Samsung KM48S2020CT-GH
Hyundai/Hynix HY57V168010A TC-10
From what I understand, those should be 16Mbit x8 chips, so I expected 16 chips to equal 32MB per module. But this board seems to only detect half of each stick.
Questions:
Has anyone successfully run 64MB SDRAM on a Soyo SY-5VD / Intel 430VX board?
If yes, what exact RAM part numbers worked?
Is this board known to only detect one bank/side of certain 32MB SDRAM DIMMs?
Should I give up on SDRAM and use 72-pin EDO SIMMs instead?
I’m not trying to chase 128MB anymore. I just want a stable 64MB setup for Windows 95 / DOS / early 3Dfx gaming.
Any known-working RAM part numbers would be appreciated.
Reply 1 of 7, by rmay635703
Sounds like normal behavior,
Intel vx doing Intel vx things.
If you can EDO is easier to work with.
Single 64mb VX specific SDRAM IS MASSIVE with a double decker of low density chips on both sides.
8 and 16mb sdram is guaranteed to work, 32mb needs to be double sided low density, it’s getting rarer than EDO simms.
Reply 2 of 7, by Repo Man11
There was a member of Vogons that found a SDRAM DIMM that read as the full 64 megabytes on a VX board, but it seems they're as rare as hens teeth. EDO SIMM memory is (by far) the easiest way to go with the VX chipset.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 3 of 7, by rmay635703
Repo Man11 wrote on 2026-07-08, 23:20:
I have a massive vx specific 64mb sdram, it’s 5v gets unstable at 66mhz FSB (60 is fine) and is keyed in such a way it only fit one board I had.
Not recommended
Reply 5 of 7, by Skazzaks
Thanks everyone, this helps a lot.
Sounds like this is mostly just normal Intel 430VX behavior, not necessarily anything wrong with my board. I didn’t realize how much the chipset mattered when it came to SDRAM compatibility.
At this point I’m probably going to stop chasing random SDRAM sticks. The realistic route with this board seems to be either staying at 32MB SDRAM for now, or switching to EDO SIMMs and trying for 64MB that way. From what I’m gathering, 64MB of EDO is probably more useful for a Windows 95 gaming build than being stuck at 32MB SDRAM, even if SDRAM is technically faster.
This also wasn’t the board I originally planned to use. I had picked up an ASUS TX97-E, but the one I received had issues and had to be sent back. Since then, every TX97-E I’ve found has been way more expensive. I ended up grabbing the Soyo because it was cheap and seemed close enough for what I wanted, but now I’m learning where some of the older/budget chipset limitations are.
Thanks again for all the explanations and chipset info. You probably saved me from buying a bunch more random SDRAM and hoping for the best.
Reply 6 of 7, by jakethompson1
Yes, this is normal 430VX. The VIA VPX is what I have on the board I linked above which has the same issue. 64MB in EDO SIMMs makes a lot of sense. In fact, I have a Biostar 430VX board that doesn't even have DIMM slots on it.
Based on the timings in the 430VX datasheet the EDO is about 20% slower than the SDRAM. But you can always do what I linked above to a 256MB DIMM someday to turn it into a 64. And the cache (especially if you have the 512K model) goes a long way toward smoothing this over as well and 64MB is the cacheable limit (by the way, the 430TX still has this limit!) anyway. Your Pentium MMX has double the internal cache of a plain Pentium as well.
Reply 7 of 7, by rasz_pl
Skazzaks wrote on 2026-07-10, 21:26:
Re: Ideal gaming system specs per year? (Esp. 1983 - 1992?)
Probably nothing playable on MMX233 with voodoo1/2 will feel much difference between 32 and 64MB of ram. Your main bottleneck will be CPU followed by graphics with mechanical HDD between the levels.
