First post, by pelagiad
  • motherboard: MSI 845E Max
  • cpu: Pentium 4 @ 2.40 GHz
  • ram: 512 MB
  • video board: GeForce 4 Ti 4200 (Driver ver. 8.1.9.5)
  • sound board: Realtek AC'97 (Driver ver. 5.10.0.5740)
  • os: WinXp (ServicePack 2)
  • game: Inherit The Earth (german Version: Erben der Erde)
  • problem: game can smoothly be installed using DosBox. when trying to start the message "cd is an audio cd!" appears. the cd is from an old bestseller games magazine.
  • reproducibility: everytime trying to start the game
  • sound mode: (don't know the required - check conf-file attached to post
  • video mode: surface (don't know, if this is the required information - otherwise check conf-file attached to post)
  • emulator: DosBox ver. 0.63
  • taken measures: the were no problems reported on the DoxBox Website, that are similar to mine. this is the only note to this game:
    note from MAN-biker: CD-ROM version. Troubles with install. Installed game works good with all sounds, but with not much fps. (run on P4-2GHz/WinXP)
    i already tried to get some help from another forum - without success.
thx in advance,
pelagiad
www.pelagiad.tk
    dosbox.conf.txt
    5.15 KiB
    70 downloads
    DosBox ver. 0.63 config-file
Reply 1 of 3, by LoneLines
If you're getting problems you should try playing with ScummVM, the new 0.8.2 version plays ITE as well, I think it should also support the German version (though I'm not sure).
LoneLines list of workarounds for various games in DOSBox:
http://ADogsBox.jellofishi.com
Reply 3 of 3, by LoneLines
Did anyone manage to run the CDROM version of the game in Dosbox?
http://www.jellofishi.com/gamewiki/index.php? … e_Earth_-_CDROM
