Running AMOK?
First post, by Red5
So I was having something of a spring clean yesteraday and came across my copy of A.M.O.K. then I remembered DosBox... I wonder if it's been updated recently? (not having looked for over a year!) Great it was updated just this week to v0.65, and AMOK is listed as working (slowly) with v0.61 😀
Unfortunately I can't get AMOK to run, it just keeps telling me that MSCDEX isn't installed and I'm pretty sure I've used the correct mount settings (using D-Fend, and also trying manually!)
mount c c:\Dos (for the virtual C drive)
mount d d:\ -t cdrom -ioctrl (for the actual CD)
I'm pretty sure the drive doesn't need a Label BTW as WinDoZe tells me the disc is "Untitled". Does anybody know if AMOK still works, and if so how!? (I'm using the Valuesoft budget re-release if that makes any difference)
