First post, by gish
Kings of the Beach works flawlessly in EGA mode, but uses the PC tweeter for sound. If I try playing in Tandy mode, I get the full 3-voice synthesizer.
However, when I the game starts after you select Tournament in Tandy mode, DosBox crashes. In the DOS command window it reads:
Exit to error: Dyncore: Illegal option in opcode oxff.
The game works fine in EGA mode but unfortunately this game does not support adlib sound the only advanced sound to use is the Tandy 3 voice.
Running:
P4 3.4Ghz 2GB RAM
SB Audigy 2
Anyone else get this problem? Thanks!
Reply 3 of 5, by gish
I've tried using the other CPU cores, but none of them seem to make the game work properly. Any ideas?
Normal:
Exit to Error: CPU: GRP5 Illegal Call 7
Full:
Game just hangs ... no exit to error.
Dynamic:
Exit to error: Dyncore: ILlegal option in opcode 0xff.
Simple:
Game does not load at all.
Thanks again for the help!
Reply 4 of 5, by DosFreak
Your using DosBox 0.65 right?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
