First post, by Shed
- Newbie
FastTracker II , with 25.000 cycles ....
Yeah, FT2, IT, and ST3 all work fine with DosBox 0.63+ (and probably earlier too).
Runs with a lot more tracks as well btw 😉
this is great, thank you dosbox team and testers!
Dynamic core with sound blaster seems as currently best solution, because GUS-mode produces few problems with 16-bit sounds...not sure if emulation or FT2's fault.
i play with config and finally get this one ...
