Daggerfall
Reply 20 of 60, by TechnologicallyImpaired
I fixed it 😀 for anyone curious here's what I did:
Start dosbox, make sure the cd is in the e drive
Hit alt, ctrl, and enter to make a full sized screen
Type "mount e c:\" and hit enter
Type e: and hit enter
Type cd dagger and hit enter
Type dagger and hit enter
Reply 21 of 60, by mrfrodo
Okay, thanks for your help.
I used dosbox to install daggerfall in the directory c:\dagger. had to use the freesize command to free up some rume for the huge install.
I used dosbox to execute the 2.13 patch.
I downloaded the extra quests and placed them in the arena 2 folder.
then
i changed z.cfg path and pathcd to c:\dagger\arena2\
that was saved
then
i opened dosbox-0.73-conf and saved asdaggerfall.conf with the following changes: memsize=40, frameskip=1, cycles 20000
at the bottomof the file I placed these commands:
mount c c:\dagger
c:
fall.exe z.cfg
this file was saved as daggerfall.conf
i made the shortcut using the appropriate target: "C:\Program Files\DOSBox-0.65\DOSBox.exe" -conf daggerfall.conf -noconsole
for the icon change:C:\DAGGER\DAGGER.ICO
this was saved
the only oddity is that i am using 64 bit vista. i am also using ubuntu, but i am not as far along in figuring out how to do it there.
what do you think i have done wrong?
Thanks again for your help.
frodo
Reply 22 of 60, by DosFreak
You change z.cfg to c:\dagger\arena2\ but since you mounted the virtual "C" as "C:\dagger" then ere is no "C:\dagger\arena2" there is only \arena2.
Make your games work offline
Reply 24 of 60, by mrfrodo
DosFreak, that totally fixed the issue. daggerfall works. that is great.
the only last issue is to get the daggerfall.conf to work with the short cut.
I am going to look through ans see if i can find any errors and then I will get back to you.
It is nice learning about dos
frodo
Reply 25 of 60, by mrfrodo
this is my shortcut path: "C:\Program Files (x86)\DOSBox-0.73\dosbox.exe" -conf daggerfall.conf -noconsole
these are the changes to dosbox.conf that is now daggerfall.conf. this file is located in the location previously mentioned.
memsize=40
frameskip=1
cycles=20000
and at the very bottom
mount c c:\dagger
c:\
fall.exe z.cfg
my understanding is that these commands tell dos to create a virtual c drive that is the dagger folder. then it changes directory from z to this virtual drive, then execute these two commands.
that seems like it should do the trick. what do you think?
Reply 26 of 60, by MiniMax
Rank Moderator
Moderator
mrfrodo - how many folders do you have on your PC?
_________________
Reply 27 of 60, by MiniMax
Rank Moderator
Moderator
Any theories as to why Daggerfall will not detect the MPU-401 as its MIDI-device?
_________________
Reply 29 of 60, by DosFreak
radiation from an exploding star?
Reply 30 of 60, by MiniMax
Rank Moderator
Moderator
Not only a theory, but a proof: When MIDI-volume on your Windows PC is turned all the way down, nothing is heard! 😒 😊
_________________
Reply 31 of 60, by MiniMax
Rank Moderator
Moderator
So... I have been playing around a bit with new free release, and this is the dosbox.conf file I ended up with.
My setup differs a bit from the official installation guide.
I don't recommend doing the "Huge" install. It might have made sense back in the day when the non-installed parts of the game would have to be pulled of the slow CD. But with the emulated CD-ROM in DOSBox, I don't believe there will be any speed difference, so I suggest you do a "Minimum" install instead.
The official guide also says to use an Sound Blaster 16 for the MIDI device. I like the MPU-401 device better (using port 330), so that is what I chose.
    dosbox.conf
    4.53 KiB
    270 downloads
    DOSBox 0.73 configuration for TES II: Daggerfall by MiniMax
_________________
Reply 32 of 60, by HunterZ
I still have my original CD, but I downloaded the free release just for the heck of it.
I highly recommend not playing at cycles=max because once you reach a certain processing speed the game will start to act flaky. It will become very hard to climb walls, move any direction other than forwards, or to jump (most of these symptoms are more noticeable in large cities). I used to experience this behavior on my 450MHz Pentium II (I even contacted Bethesda and they didn't believe me) and I reproduced it a couple hours ago in DOSBox.
Running with fixed cycles at 30000 or more seems to work well.
Also, MPU-401 definitely works in DOSBox. I've used it with my SC-88 before, and I just used it with Win7's built-in software synth.
As for installation size, it's probably actually best to install huge and use the hack to make it run without mounting the CD, but hey disk space is cheap these days so I followed Bethesda's instructions out of laziness 😀
Reply 33 of 60, by MiniMax
Rank Moderator
Moderator
Thanks. Noted.
Huh? So instead of mounting TWO folders in a standard way, you prefer to hack an internal configuration file and manually copy files?
_________________
Reply 34 of 60, by mrfrodo
Minimax,
You want to know how many folders are on my computer? I am not sure I could count them all in my life time. How can this be related to why the daggerfall shortcut and daggerfall.conf are not making the appropriate changes to dosbox when they are executed? If you can give me more information about it I might be able to answer you.
thanks a lot for your time.
Reply 35 of 60, by HunterZ
Yeah, because it feels better that the game is self-contained in one directory and not needing any special configuration (e.g. mountings).
The main point thought was that I'm not too worried about wasting 0.5% of my hard drive capacity if I choose to be lazy :p
Reply 36 of 60, by ripa
You can use
cycles=max limit 30000
instead of fixed 30000. This way sound won't stutter if the emulation can't keep up with 30000 cycles.
Daggerfall and Arena came on CDs. Did they have redbook audio tracks?
Reply 37 of 60, by eL_PuSHeR
I think not because Bethesda recently released Daggerfall as freeware and it comes inside a ZIP file.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 38 of 60, by MiniMax
Rank Moderator
Moderator
mrfrodo wrote:
Minimax,
It is related in this way:
If you have so many folders that you can't count them in a life-time, how do you suppose your computer would know which of all those folders that contains your daggerfall.conf file? Maybe help it a bit by telling it the exact path.
_________________
Reply 39 of 60, by HunterZ
ripa wrote:
You can use cycles=max limit 30000 instead of fixed 30000. This way sound won't stutter if the emulation can't keep up with 3000 […]
You can use
Hmm thanks I'll play with that.
Nope. Battlespire does but Arena and Daggerfall both use MIDI music.
